Be Cool radiator install for automatic? Pics?
Old Jun 20, 2003 | 09:49 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default BeCool radiator install for automatic? 4 holes for on passenger side? Pics
I just recieved the radiator frok BeCool and it states I need to brass fittings for the transmission cooler to be put in the radiator. ANyone know if I cna buy these anywhere, as I have the size. Also, there are four threaded holes altogether on the passenger side, 2 I presume for the tranny, what about the other 2? Any Pics?
[Modified by steve40th, 11:51 PM 6/20/2003]
Old Jun 20, 2003 | 11:28 PM
Fast Glass's Avatar
Fast Glass
Default Re: Be Cool radiator install for automatic? Pics? (steve40th)
I may not be able to help you out with the tranny cooler lines too well. I used pipe to AN4 unions at the radiator side. Hooked up a couple sections of #4 braided line to #4-#5 reducers that hook up to the stock line near the trans that I cut and flared to #5AN.
The other 2 holes on the right side are for- top hole is low coolant sensor (bought from Ecklers). Bottom hole is for drain.
I also took out the stock rubber mount pieces, and used 3" sections of heater hose cut lenghtwise down the center to mount the radiator. I put one on each corner, and it is holding nicely. Also had to cut the upper shroud a bit to get everything to fit.
I don't have any pictures right this minute, but I can get some pics tomorrow of the installed unit to you.
Old Jun 21, 2003 | 02:37 AM
steve40th's Avatar
steve40th
Default Re: Be Cool radiator install for automatic? Pics? (Fast Glass)
Thanks, If you could email me the installed photos that would be coool. Thanks, Steve corvettesrule@hawaii.rr.com
Old Jun 21, 2003 | 12:48 PM
steve40th's Avatar
steve40th
ttt. last time
Old Jun 21, 2003 | 03:21 PM
Fast Glass's Avatar
Fast Glass
Pics sent.
To Be Cool radiator install for automatic? Pics?
