TPI Unit
Old Jun 21, 2003 | 01:00 AM
Vette Head's Avatar
Vette Head
Default TPI Unit
Can I put a TPI unit from a 86 on my 85? Simple question.
:seeya
Old Jun 21, 2003 | 03:19 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Default Re: TPI Unit (kirks518)
Think so. As long as both cars came equipped with the cold-start (9th) injector it should bolt right up.
Old Jun 21, 2003 | 03:40 PM
Vette9d1's Avatar
Vette9d1
Default Re: TPI Unit (TheCorvetteKid)
I'm almost positive they are the EXACT same!
Old Jun 21, 2003 | 03:57 PM
sumoboy's Avatar
sumoboy
Default Re: TPI Unit (Vette9d1)
:iagree:
As far as I know the cold start inj was from 85-88.
Old Jun 21, 2003 | 04:02 PM
dppeaden's Avatar
dppeaden
Check the book, TPI Swapers Guide. :seeya
Old Jun 21, 2003 | 04:19 PM
scorp508's Avatar
scorp508
Do you mean the entire intake manifold, plenum, runners? Or just the plenum/runners? Did the unit come off of an iron or aluminum head 86?
Old Jun 21, 2003 | 08:52 PM
joalyons's Avatar
joalyons
Default Re: TPI Unit (scorp508)
Scorp is right on, are they both aluminum heads? If not there may be a diff, it wont be the cold start that goes thru 88. You can check the Accel web site for their intake and see if they list a different one for 85 to 86. If they don’t it should bolt right up.
To TPI Unit
