Early C-4 window regulator upgrade question
Old Jun 22, 2003 | 09:18 PM
kize's Avatar
kize
Default Early C-4 window regulator upgrade question
I own a early 86 (iron heads). I've been fighting the plastic ribbons on my window regulators for a year. Finally gave in and purchased used 88 window regs that are the scissor type. This is the question- Where do I get measurements for hole placement on bottom of door for the lower regulator mounts? Is there some pattern out there for proper location? I figured 2 holes would have to be made in bottom of door for bolts to mount lower regulator frame. Has anyone done this? Your guideance would appreciated.
Old Jun 22, 2003 | 09:25 PM
Bluevette85's Avatar
Bluevette85
Default Re: Early C-4 window regulator upgrade question (kize)
I did this and one of the holes was already there. I measured over from it to drill the second hole.
Old Jun 22, 2003 | 09:28 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: Early C-4 window regulator upgrade question (Bluevette85)
I bought a new one, and it came with a template with measurements for the holes. Unfortunately I don't still have the measurements. Maybe someone else on the forum does.
Old Jun 22, 2003 | 09:30 PM
kize's Avatar
kize
I'll have to check again. The only hole I noticed was the original mount hole for the old reg- totally different location ( forward on the door).
To Early C-4 window regulator upgrade question
