"Check Engine"...........Well F
Old Jun 23, 2003 | 08:00 AM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default "Check Engine"...........Well F
ok start the car this morning and i get a CHECK ENGINE light. I am gonna pull codes later today. Anyone have a reference for what the codes mean? Thanks
-Will
Old Jun 23, 2003 | 08:02 AM
hngacurv's Avatar
hngacurv
Default Re: "Check Engine"...........Well F (flyinace2000)
http://www.flash.net/~abilling/gmcodes.htm
Old Jun 23, 2003 | 08:19 AM
flyinace2000
Default Re: "Check Engine"...........Well F (hngacurv)
Thanks :thumbs:
Old Jun 23, 2003 | 09:11 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Get used to it. SES is a fact of life for us OBD1 owners... :yesnod:
Old Jun 23, 2003 | 11:03 AM
Steel Blue 91's Avatar
Steel Blue 91
or
http://www.c4vettes.com/ecm.htm
Old Jun 25, 2003 | 09:06 AM
flyinace2000
Default Re: "Check Engine"...........Well F (Steel Blue 91)
Good news, problem went away time lunch came around and no codes were present. :crazy:
Old Jun 25, 2003 | 11:26 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
You still need to puill the codes and see what caused the SES light to illuminate.
You 'may' be able to head off an upcoming problem or at least get a little heads-up on it.
Could be nothing important but when your car talks to you, you should at least listen.
Old Jun 25, 2003 | 12:25 PM
flyinace2000
Default Re: "Check Engine"...........Well F (VetNutJim)
Well when i hooked up the computer to the scanner no codes were present. So i got nothing.
Old Jun 26, 2003 | 01:36 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If the check light comes on, the ecm stores a code. It remembers the code until you reset it by disconnecting the battery cable for 10 seconds.
Soo... are you sure you checked it right? You don't need a scanner, a paperclip will work fine.
To "Check Engine"...........Well F
