Gas smell????
Old Jun 23, 2003 | 11:26 PM
jiangtao75's Avatar
jiangtao75
Default Gas smell????
I have an 86 that has 52000 miles on it.The owner before me kept it in awesome running condition.BUT.I have been driving it regularly and I noticed a gas smell when I crank it and when I come to a stop.I checked everwhere and found no leaks!I can smell it on the driver's side and under the seat around the back tire on the driver's side.Fuel pump and filter have been changed recenlty.Anyone know what this might be?As for the car's running and performance,it's great.Any help would be greatly appreciated.
Old Jun 23, 2003 | 11:32 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: Gas smell???? (jiangtao75)
:confused: well you've got me :yesnod:
the fuel lines are on the passenger side
Old Jun 23, 2003 | 11:41 PM
vader86's Avatar
vader86
Probably bad injectors. They would cause a smell on startup, might be running unburned stuff into the exhaust and thats what youre smelling.
Does she start right up when the engine is hot and been sitting for a couple minutes, or does it take a second or two longer than when cold.
Old Jun 24, 2003 | 10:28 AM
jiangtao75's Avatar
jiangtao75
Well,now that I think about it,sometimes it takes a few seconds to start up after I have been driving it.When its cold it will start right up.There is no smell coming anywhere from the engine though!
Old Jun 24, 2003 | 10:54 AM
SunCr's Avatar
SunCr
Check vapor canister and lines, particularly around the tank since the fuel pump was replaced.
Old Jun 24, 2003 | 01:14 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I do recommend that you find it ASAP....before driving it too much.....
Theres danger in them there hills....well you know what I mean...
tony
:eek: :smash: :eek:
[Modified by oldace84, 10:15 AM 6/24/2003]
Old Jun 24, 2003 | 02:16 PM
Mike263's Avatar
Mike263
A steel line goes from the evaporative canistor (fuel vapor recovery system) to the fuel tank along the driver's side. There is a section that is rubber fuel line just ahead of the the rear tire on that side - bet it's cracked - speaking as the voice of experience.
[Modified by Mike263, 1:17 PM 6/24/2003]
Old Jun 24, 2003 | 06:56 PM
ittlfly's Avatar
ittlfly
Default Re: Gas smell???? (Mike263)
:iagree: I'll bet he's right.
Old Jun 24, 2003 | 09:21 PM
joalyons's Avatar
joalyons
Default Re: Gas smell???? (ittlfly)
Or when the lines were taken off to change the pump the got cracked, take off the fuel door and look.
Old Jun 24, 2003 | 09:23 PM
O'Shark's Avatar
O'Shark
:iagree: I had the exact thing happen. It was the short rubber section that was cracked. It helped but I still smelled fuel. It was the fuel cap! If you don't hear that pressure hiss when you loosen your cap, that may be your problem too.
Old Jun 25, 2003 | 12:42 AM
Rick86's Avatar
Rick86
:yesnod: :yesnod: :yesnod:
Old Jun 25, 2003 | 08:23 PM
Mad Maxwell's Avatar
Mad Maxwell
Ditto what those guys said on my '86. It was the short rubber section joining the evap lines just ahead of the left rear wheel.
-Evan
To Gas smell????
