Accel Runners
Old Jun 24, 2003 | 09:26 AM
JayB119's Avatar
JayB119
Default Accel Runners
Is it worth buying them if I can get them for $200?
Old Jun 24, 2003 | 09:40 AM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: Accel Runners (JayB119)
why not :cheers:
Old Jun 24, 2003 | 09:50 AM
Aaron's 87's Avatar
Aaron's 87
Not if you don't port the plenum and intake manifold.
Old Jun 24, 2003 | 09:59 AM
helopilot's Avatar
helopilot
I've got the Accel runners on my '85-it came with them already installed-and after driving another stock '86, my car does feel like it has a stronger mid-range. As far as I know my '85 doesn't have any other engine mods that I know of (I bought it as a repo so I don't have any history on it). Don't know if that helps but $200 sounds pretty darn reasonable. :flag
Old Jun 24, 2003 | 10:32 AM
Ramanstud's Avatar
Ramanstud
Default Re: Accel Runners (helopilot)
Buy em!
If you're too lazy to port (or buy) a ported plenum, then sell them here for $300 and make a little off the deal. :jester
Old Jun 24, 2003 | 01:33 PM
JayB119's Avatar
JayB119
If I port the plenum but not the intake manifold will this modifacation help at all?
Old Jun 24, 2003 | 01:35 PM
krivera's Avatar
krivera
i would save up and get the AZ Speed and Marine Siemes ones. :D
but that is me
Old Jun 24, 2003 | 01:59 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Yes they will help without any porting work to the intake. The runners are the most restrictive part of a TPI and that's including the base.
Old Jun 24, 2003 | 05:10 PM
Aaron's 87's Avatar
Aaron's 87
Default Re: Accel Runners (NUckINg FuTS)
My results differed. The runners were not great, but better than the manifold. The heads (early AL) were pretty bad too; the exhaust side was awful.
Now, if you put on 1.7" diameter runners on an intake manifold that's only 1.5", you've got a .1" wall the air is flowing into and creating an eddy that tightens the effective diameter. Plus, you're feeding the 1.7" runners with a 1.5" plenum. Bolting runners on without porting would probably yield no gains or even a loss.
The good thing about the cast runners is that you can siamese them.
Old Jun 24, 2003 | 06:15 PM
jmrl98's Avatar
jmrl98
JayB119, you can use my dremmel to port your plenum. I did it to mine, it is real easy. I live in Hazel Park, so I'm not far. I could guide you through it. You can IM me if you are interested. :seeya :steering:
Old Jun 25, 2003 | 03:46 AM
smar's Avatar
smar
I would grab them then save up few bucks and buy TPIS Big Mouth manifold and have a winter porting project.
I did the same thing works well
:seeya
Old Jun 25, 2003 | 08:13 AM
TA's Avatar
TA
I don't think you'll see much of a gain until you do all three (runners, plenum, intake)
Old Jun 25, 2003 | 09:10 AM
JayB119's Avatar
JayB119
Thanks for all the help. I think I am going to buy them and if I have to wait to port the other two things at least I have the runners done.
To Accel Runners
