Installed the throttle body bypass, 160 thermostat, and programmed the fans for 195 to 185. I even attached a funnel under my frame through a hose to the throttlebody to provide air cooling. The bottom line is that after a short ride, 15 to 20 minutes, the throttle body is noticeably cooler. However if I drive for 45minutes or more, the heat from the manifold is transferred to the throttlebody and the darn thing is as hot as ever. Thereby negating all of my hard work. What am I missing?
Re: Throttle Body Bypass - Disappointing results (94 Red Roadster)
what you need to do is take off the intake and get the bottom side jet coated or poweder coated to get the oil to not stick and to reflect oil and heat! that is the true way
The hood of a C4 is like a clam-shell. And fiberglass is a great insulator of that heat generated under it. I thought about installing two NACA ducts on each side of the hood to flow some cool air through there or a pair of 12VDC fans mounted to the inside of the lower wheel wells to route hot air out over the tire. There's just no ventalation under there so everything will absorb the heat eventually. And aluminum is the second best heat conducting metal known to man (copper being first).
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Throttle Body Bypass - Disappointing results (krivera)
:cheers: Thoroughly confused :confused: :D
The water to TB is supposed to heat it up to prevent icing
Not surprised bypassing TB is disappointing
If you take the TB apart and look at how much coolant actually goes through there you will realize why you where/are disappointed.
More heat from the engine affects the TB once engine is hot, than heat from the little amount of coolant going through it. I am afraid, IMHO, that this "free mod" is worth less than what it cost you!
It's like cutting out the filter lid, except the filter lid mod may actually offer a little positive result at speeds over 80+ MPH
Re: Throttle Body Bypass - Disappointing results (Southern Comfort)
If you really want to reduce heat soak you can cut the part of the throttle body that the coolant flows through OFF. Less metal, less heatsoak but theres no return once you do this mod :D
Re: Throttle Body Bypass - Disappointing results (Dr. Evil)
No need to cut, it unbolts.
I had good luck with thicker gasket on my cast aluminum runners, thicker gasket reduces heat transfer. My plennum is fairly cold considering fact that there is flow of hot air from the radiator.
Re: Throttle Body Bypass - Disappointing results (jackdaroofer)
:confused: :D
:seeya
:steering:
:iagree:
exactly what WERE your expectations?
This mod is, and never was meant to show any major results in either direction. This is one of those "free" mods that have an accumlitive affect on yuou performance....that you may NEVER notice.
The only way to really cool your TB (in my opinion) is to have cool air blowing directly to it, but I still wouldnt expect much of an improvement during the summer months.
I found that by just removing the "T's" where the throttle body lines go into the main water hoses works best. It gives a much cleaner look by replacing the T's with straight connectors. Just my $.02
The TB bypass combined with a 160 stat. was one of the best things I did for my L98. The plenum is raised to allow air to flow under it. For me, the plenum is a good place to put my hands when I'm doing engine work. I had to use towels and gloves to put my hands on there before the bypass. Now I can use my bare hands! :cool:
Re: Throttle Body Bypass - Disappointing results (65Z01)
While I havent done this on the vette I have done it to my 96 Impala. However I also have a ram air setup that allows over flow air to run past the TB keeping it a bit cooler. It also doesn't suffer as much from the heat soak as it has iron heads.
The best way to beat heat soak on a daily driver is probably to get a ram air system that passes air over the TB. my .02
