85 Running Hot
Does this sound like a bad thermostat or bad ECM or something else?
Thanks!
First thing, clean the front of your radiator. In between the rad and the condensor, there will be a ton of trash. Just removing that will lower temps 10-15F if its really clogged. Flush and refill the radiator.
The main fan comes on at 228F, I would make sure its doing so, and then buy a fan switch from Ecklers or MidAmerica and wire that to the main fan so that it will come on sooner. The only other way is to get someone here to reprogram the chip's fan settings.
I would at least change the thermostat to a 180, I run a 160 in my 86. Whether you use 160 or 180 depends on how much you drive her in winter. I run mine in winter quite a bit, but winters here are rather mild. The stock stat is 195, which i think is too high. Just from installing a lower temp stat, the average running temperature should drop 10F. Mine dropped a little more because of the 160. I'm sure someone else will chime in and say that the 195 is the only one you should run, I leave it up to you to decide.
