Ignition coil difference between '92 and '96 LT1????
Old Jun 24, 2003 | 09:57 PM
Tom Piper's Avatar
Tom Piper
Default Ignition coil difference between '92 and '96 LT1????
The '92 to '95 LT1 is supposed to have one type of ignition coil and the '96 LT1/LT4 is supposed to have a different one.
What is the difference between the two types?
Is there a difference in the ignition module/driver?
Tom Piper
Old Jun 24, 2003 | 10:13 PM
superlund's Avatar
superlund
Default Re: Ignition coil difference between '92 and '96 LT1???? (Tom Piper)
I've read where the GM upgraded it to a higher output coil in 96' don't have any specific numbers though.
Old Jun 24, 2003 | 10:37 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Ignition coil difference between '92 and '96 LT1???? (superlund)
:withstupid:
The '96 one supposedly has slightly better output at the very high end, like over 5500rpm or something. Nothing a set of good low resistance pluig wires and coil wire couldn't help compensate for with the '92 - '95 coil :yesnod:
I've heard that if you run one of the after market very high output coils on an LT1 or LT4 it can cause carbon tracking to start building up in the opti spark distributor.
To Ignition coil difference between '92 and '96 LT1????
