small shake in steering wheel when hitting bumps
Old Jun 24, 2003 | 10:10 PM
dmorris's Avatar
dmorris
Default small shake in steering wheel when hitting bumps
When I hit small bumps in the road, I get a little shake in the steering wheel. I have checked out the suspension and everything seems okay. Should I be concerned. I don't have any free play in the steering. I have a small amount of play in the tilt column ( maybe 1/4 inch). Could this be the play in the column?
Old Jun 24, 2003 | 11:25 PM
PsychoVetteOwner's Avatar
PsychoVetteOwner
Default Re: small shake in steering wheel when hitting bumps (dmorris)
I get the exact same thing with my 89. All the suspension has just been checked.
Replaced the tires, new balancing, and an alignment. Still does the same thing.
My guess is, the body itself is so stiff, as well as the suspension, that no matter what you do, this is just one of the many "character traits" that we all have to deal with
Old Jun 24, 2003 | 11:33 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Just a silly thought.....how about checking the alignment....bet its time for a complete 4 wheel job....
Find a good shop in your area that does Corvettes...
then you will get it done right....
check it out with other corvette owners in your area....
been there done that...
Good Luck
tony
:smash: :smash: :smash: :smash:
[Modified by oldace84, 8:34 PM 6/24/2003]
Old Jun 25, 2003 | 01:10 PM
FELNGR8's Avatar
FELNGR8
Get ready to spend some money. I bought the RD Racing Camber brace and Cross Bar to stiffen the body. Then I put on Z51 Bilsteins last weekend.
No shake in my steering over bumps any more. Tight as a racer.
Old Jun 25, 2003 | 05:00 PM
vetracer's Avatar
vetracer
Default Re: small shake in steering wheel when hitting bumps (94lt1torchred)
:iagree:
The camber brace from R-D Racing WILL cure this problem, it is typical of C4's.
Old Jun 25, 2003 | 05:18 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: small shake in steering wheel when hitting bumps (vetracer)
:iagree:
:withstupid:
my '95 has been aligned and balanced etc. but I get the shake also when I run over bumps.
Old Jun 25, 2003 | 05:33 PM
uralman's Avatar
uralman
try the camber brace. it seemed to help mine.
Paul
Old Jun 25, 2003 | 06:22 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers:
What's your tire pressure?
How old are the shocks(maybe you aid this and I missed it)
If you have the Z 52 or the Z51 suspension, the camber brace may not do you much good IMHO
:seeya
:steering:
Old Jun 27, 2003 | 07:30 PM
dmorris's Avatar
dmorris
Default Re: small shake in steering wheel when hitting bumps (jackdaroofer)
I run my tires at 35 psi and the shocks are new. I do not have the z51 suspension. I have not had the tires ballanced or an alignment done since I've had the car (6 months). It isn't that bad, but I wanted to see what others thought before I started throwing money at a problem.
Old Jun 27, 2003 | 08:40 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
:cheers: 35 psi, cold, maybe a little high in the front tires
Try 32 psi cold
[Modified by jackdaroofer, 8:42 PM 6/27/2003]
Old Jun 28, 2003 | 11:04 AM
honas's Avatar
honas
Mine only feels that way when the top is off.
To small shake in steering wheel when hitting bumps
