The fuse keeps blowing
Old Jun 25, 2003 | 10:08 PM
Thumper's Avatar
Thumper
Cruise-In II Veteran
Default The fuse keeps blowing
I have had an 02 sensor code 13 for a while now. I finally decided to check into it yesterday and noticed there was a 15a 02 sensor fuse. I pulled the fuse and it was blown. No problem, I go pick up another fuse, throw it in, clear the codes, start the car and the code comes back. I pulled the fuse and it was blown :mad I hope this is not a short. Any ideas what might be causing the fuses to blow and how to fix it?
Old Jun 25, 2003 | 10:11 PM
bogus's Avatar
bogus
Default Re: The fuse keeps blowing (Thumper)
I would disconnect the O2s and see if the fuse blows.
if not, replace the O2s and make sure the connectors are good.
