Change Engine Oil Light
Old Jun 26, 2003 | 06:44 PM
navigate's Avatar
navigate
Default Change Engine Oil Light
I apologize in posting this note. I know I've read it a dozen times, but can not locate the thread. The CHANGE ENGINE OIL light has popped on my '94 with 24K on the O.D. What is the procedure to reset this warning light?
Thanks in advance.
Bob
Old Jun 26, 2003 | 09:20 PM
jimswhite92's Avatar
jimswhite92
Default Re: Change Engine Oil Light (navigate)
Resetting "Change Oil" indicator on a '94
1. Turn ignition "ON" but do not start engine.
2. Press the "ENG/MET" Button and release, then, within 5 seconds, press it again.
3. Within 5 seconds of step 2, press and hold the "GAUGES" button. While the button is held,
the "CHANGE OIL" indicator will flash.
4. Continue holding the "GAUGES' button until the "CHANGE OIL" indicator stops flashing and goes out, indicating successful completion of the reset cycle. If id does not successfully reset, turn the ignition "OFF" and repeat the procedure from step 1.
Old Jun 27, 2003 | 10:38 AM
navigate's Avatar
navigate
Default Re: Change Engine Oil Light (jimswhite92)
Jim
Thank you Sir! Much appreciated.
Bob
To Change Engine Oil Light
