Need some Mini Ram pic's and advice
Old Jun 26, 2003 | 11:32 PM
1990z's Avatar
1990z
Default Need some Mini Ram pic's and advice
I am in the middle of installing a Mini-Ram. I was wondering if I could see some close up pictures of the plenum and how everything is hooked up. Does the stock screw, that holds the distributor down, fit the Mini-Ram? How do you install the fuel rails? Any help is greatly appreciated.
Thanks,
Jeff
Old Jun 27, 2003 | 04:34 PM
ELEVENS's Avatar
ELEVENS
Default Re: Need some Mini Ram pic's and advice (1990z)
This was just covered in a thread within the past two weeks or so. Maybe start with a search.
:cheers: -Bill
Old Jun 27, 2003 | 06:04 PM
Fast Glass's Avatar
Fast Glass
Email sent with pictures. Hope they help.
Old Jun 27, 2003 | 06:17 PM
grumpyvette's Avatar
grumpyvette
Default Re: Need some Mini Ram pic's and advice (Fast Glass)
http://www.tpis.com/
(Installation Instructions )
(Mini-Ram Intake)
Mini-Ram Installation Instructions
1. Disconnect the battery
2. Turn the motor over until the timing marks line up, and the rotor points at the number 1 terminal.
3. Removwe the distributor noting the position of the rotor so you will have it correct on reinstallation of the distributor.
4. Remove your existing induction system. Clean all gasket material from heads and block. Temporarily set new gaskets in place with Mini-Ram and check bolt holw alignment. Make sure the oil pressure fittings have clearence at the back of the manifold. The fitting should be in place before installing the manifold.
5. Bolt the Mini-Ram into position. We recommend using silicone to seal the ends of the manifold instead of cork or rubber end gaskets.
6. Now install the injectors and fuel rails. ,Use a lubricant , like WD-40, to help slide the o-rings into position. Insert the injectors into the fuel rails (electrical connection facing out), and snap retaing clips into place. Now press each rail assembly into position making sure all of the injectors are completely seated. Make sure the fuel transfer tube is properly seated between the two rails. Loosely install the hard fuel lines to the fuel rails. Select the proper fittings from the fuel rail kit to connect the fuel lines to your car. Once this is done tighten the hard lines at the fuel rails.
7. Reconnect the battery. Turn your ingnition key to the run position to energize the fuel pump. Adjust the pressure to 47psi as a starting point. Check for leaks. There are twom ports ion the center of both sides of the manifold. These are for your vacuum connections. Any vacuum ports not used must be plugged. Three of the ports are 3/8" NPT, and one is 1/4" NPT (national pipe thread). We do not supply these fittings.
8. With your vacuum needs met, it is time to install your distributor. With the rotor pointing in the proper direction, set the distributor in place. It may not drop all the way in. If this is the case, turn the oil pump shaft until the distributor drops completely in.
9. Install your coolant temp. sensor in one of the tapped hole in the front of the manifold, the other one can be used for your heater. Do what ever is neater for your situation. We do not run coolant through the throttle body, It will be necessary to cut the water cavity off of your lower throttle body housing. If you take the housing off and look at the water cavity and the IAC motor cavity, you will see what needs to be cut off. You only need the IAC cavity and three mounting holes. See fig. 1.
10. Install your water neck. It uses a standard small block chevy thermostat. Fill the system with coolant and check for leaks.
11. Install your throttle body with the bolts supplied in the kit. Connect your throttle, kick down , and cruis cables. If using a stud style throttle body (85-88) you may need to use the stud extensions included in the kit for cable alignment. One bolts on the other can be tack welded. If you have a cable guided throttle body (89 or newer), use the small alum. bracket on top of the fuel rail for the throttle cable. Have someone step on the accelerator pedal to make sure the butterflies are opening all the way. Make sure the floor mats are not interfering.
12. Install your manifold air temp. sensor into the air cleaner ducting in front of the throttle body. Use the harness extension kit provided.
13. Reinstall wiring.
14. Set your base timing to 6 deg, with the EST wire disconnected. Hook up EST and disconnect the battery to clear the codes.
Old Jun 27, 2003 | 06:55 PM
LD85's Avatar
LD85
Default Re: Need some Mini Ram pic's and advice (grumpyvette)
Yes the stock distributor hold down works.
The fuel rails only go on one way
http://forums.corvetteforum.com/zerothread?id=558529
http://forums.corvetteforum.com/zerothread?id=568510
Old Jun 27, 2003 | 09:42 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Need some Mini Ram pic's and advice (ld85)
I had to do a little grinding on the inside rear portion of the left fuel rail because it was too close to my distributor cap and I couldn't turn the distributor past it to set the timing right. I told TPIS about it so maybe they have fixed that little problem since.
To Need some Mini Ram pic's and advice
