Timing cover install LT-1
Old Jun 28, 2003 | 04:14 PM
Strick's Avatar
Strick
Default Timing cover install LT-1
I'm putting my timing cover on and wondered if sealer or adhesive should be used on the gasket surfaces. What is your technique? Thanks :cheers:
Old Jun 28, 2003 | 07:10 PM
Strick's Avatar
Strick
Default Re: Timing cover install LT-1 (Strick)
Come on guys, someone out there must have successfully installed a leak free timing cover.
Old Jun 28, 2003 | 07:16 PM
96GS#007's Avatar
96GS#007
I installed mine dry. Several thousand miles later...no leaks :) Be sure to clean the block and timing cover surfaces extremely well, and then clean them once more for good measure.
Old Jun 28, 2003 | 07:34 PM
Strick's Avatar
Strick
Default Re: Timing cover install LT-1 (96GS#007)
Thanks for your reply. DRY Now that's something to think about.
Old Jun 29, 2003 | 01:58 AM
FD2BLK's Avatar
FD2BLK
I just spray on hi-tack on both sides of the gasket and thats it no leaks.
To Timing cover install LT-1
