Internal Vs externally balanced crank
Old Jun 28, 2003 | 04:48 PM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default Internal Vs externally balanced crank
Hi,
Please help me with this:
I want to know the advantage and disvantage of the internally ballanced crank ?, what kind of rods need to be used ,etc?
Let me know
regards
Old Jun 29, 2003 | 02:57 PM
ZD1's Avatar
ZD1
Default Re: Internal Vs externally balanced crank (Eduardo L98 1991)
First, internally balanced crank will rev a little better than externally balanced set up. This is largely due to NOT having a bob wieght spinning on the spout of the crankshaft.
Secondly, internally balanced cranks will balance to a bob weight. There is a special formula so it not just the wieght of all the components put together. A crank that is sold as internally balance merely means that a nominal rotating assemly can be balanced. It took $125 (included heavy metal) to internally balanced mine.
Finally as for rods, H-beam rods are normally heavier than I beam rods. Which means it would be more difficult to balance internal. you'll want to select components at the manufactuer's intended bob wieght.
