Viper 6 speed trans
Old Jun 29, 2003 | 01:33 PM
mdm's Avatar
mdm
Default Viper 6 speed trans
Anyone know anything about putting one in a c-4
Old Jun 29, 2003 | 09:16 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Default Re: Viper 6 speed trans (mdm)
There would have to be very compelling reasons to do this when it would be so much easier to put a Corvette 6-speed in a Corvette.
Did you get this Viper trans free or something?
Larry
code5coupe
:seeya
Old Jun 29, 2003 | 09:39 PM
thetoy's Avatar
thetoy
Default Re: Viper 6 speed trans (rocco16)
I seen a 93 vette last friday at the drags and he had the viper 6-speed in his car with his twin turbo setup but on the first pass he blew up his clutch.He said it wasn't to bad of a swap but he had to make his own center console because the gear shifter sits in the middle of the console.
Old Jun 29, 2003 | 09:55 PM
vette92_1's Avatar
vette92_1
I thought the Viper 6pd was a T-56 the same as whats in the F-body's?
I'm sure it's a good 6pd but I would think the vette ZF6 is just as good if not better.
Old Jun 29, 2003 | 11:51 PM
JasonL's Avatar
JasonL
Default Re: Viper 6 speed trans (vette92_1)
I believe it's basically the same unit with the possible exception of a stronger input shaft.
Old Jun 30, 2003 | 08:02 AM
mdm's Avatar
mdm
The viper trans is supposed to be alot stronger than the zf. basicaly I was trying to find out the difficulty in making the change as both of them are --from what ive been told--just about the same price-new-.
Old Jun 30, 2003 | 08:49 AM
silver & red CE's Avatar
silver & red CE
Big problem will be hooking up to the C-beam. The tailshaft housing on the ZF is made just for the Vette's C-beam. Next time you see that guy at the strip, ask him how he did it.
BTW, ZFs regularly hold up to ZR1s putting out over 700 ft*lbs of torque, you'll have to do a lot to get a SBC to that level.
Eric
Old Jun 30, 2003 | 08:57 AM
Mike in Boston's Avatar
Mike in Boston
Was this the car?
http://www.jdhcon.com/Vette.html
To Viper 6 speed trans
