Hood gas? struts
Old Jun 29, 2003 | 03:56 PM
C10 JDR's Avatar
C10 JDR
Default Hood gas? struts
My hood has one short strut (maybe 9" long) on the passenger side just inboard of the headlight, and one long (3 ' ?) strut one the drvers side to hold the hood open. There are attachment brackets for another short strut on the drivers side - but no strut. Is it missing, or should there only be one shorty?
Old Jun 29, 2003 | 07:41 PM
C10 JDR's Avatar
C10 JDR
Default Re: Hood gas? struts (britvette)
please, lift your hood and have a quick look for me
Old Jun 29, 2003 | 07:58 PM
arbee's Avatar
arbee
I think there is supposed to be two. My 87 has two.
Old Jun 29, 2003 | 08:00 PM
C10 JDR's Avatar
C10 JDR
Default Re: Hood gas? struts (arbee)
Thanks arbee --more expense :lol: :lol: :(
Old Jun 30, 2003 | 01:36 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Sorry I wasn't around to answer earlier, but I was at the Nationals. I believe it was '88 (could have been '89) they went to the improved gas charged hood prop (the long one). With this, two small assist rods became unnecessary, so naturally to reduce costs, GM dropped the driver's side small assist rod. Earlier cars had two small assist rods though. When I switched to the later gas charged prop, I replaced both small assist rods and my hood almost shot off. I ended up removing the driver's side, just to make the travel a bit less dramatic, so it's configured just like yours.
Old Jun 30, 2003 | 03:04 AM
The13Bats's Avatar
The13Bats
My 86 just has the two shorties, and the old cricket leg style prop on the passenger side, both shorties are 100% dead, I find the hood somewhat heavier than the flip clip c3 anyhoo, if I replace the two shorties on my 86 do they open the hood or just "help" and about what will be the life span of new ones?
Thanx, C. :thumbs:
Old Jun 30, 2003 | 05:54 AM
C10 JDR's Avatar
C10 JDR
Default Re: Hood gas? struts (Ray Quayle)
Looks like another C4 secret. Thanks for that! I am now a happy bunny.
Old Jul 1, 2003 | 01:05 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Default Re: Hood gas? struts (The13Bats)
Thanx, C. :thumbs:
The scissor type prop went away in very late '86. I can't remember what the exact sequence number break point was, but they went with a rod type prop and moved it to the driver's side at that point in late '86. The two small assist rods you have are just that; assist rods. On a properly adjusted hood with good parts, the hood should jump up to the fully extended spring position when you pull the release. You then lift the hood, it will feel much lighter then yours does now and the assist gets progressively higher until it will lift itself the last few inches. When I had both assist rods in, it lifted itself after I lifted just about a foot! I can send you a paper in pdf format I did on the upgrade to the late gas charged prop and hood springs, brackets, cables on my '86 if you'd like.
Old Jul 1, 2003 | 01:06 PM
Rykley's Avatar
Rykley
Ray,
I think that I might hae a problem with my struts on my hood. It is very heavy to lift. I would like to upgrade if posible. Would you be able to forward the information that you have on this to me also?
Thank you,
Tim
Old Jul 1, 2003 | 01:11 PM
The13Bats's Avatar
The13Bats
Not sure I can open pdf....but I would love to see what you have done I planned to put electric lifts on the flip clip c3.....
thanks, C.
Old Jul 1, 2003 | 01:13 PM
eric_daniel's Avatar
eric_daniel
my 85 doesn't have any struts, just the hood prop on the passenger side.
Old Jul 1, 2003 | 02:53 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Hood gas? struts (eric_daniel)
If you look at the hood hinges, there should be two shoulder pins per hinge with small holes in the ends, those are 4 hitch pins that when all is installed, prevent the struts from coming off ? ? ? ?
Old Jul 1, 2003 | 05:18 PM
C10 JDR's Avatar
C10 JDR
Can you send me that PDF Ray?
Old Jul 1, 2003 | 05:39 PM
Caboboy's Avatar
Caboboy
Another request for the PDF info here too Ray, thanks! :cheers:
Use the e-mail address: tim@baycabs.com
Old Jul 1, 2003 | 06:33 PM
mash557's Avatar
mash557
Default Re: Hood gas? struts (Caboboy)
Jeff at Superior had put together a list of parts to upgrade to the late gas charged prop. Chris should have the list. I have the scissor prop on my 86 and replaced the small gas struts and what a difference. The hood will stay up now without the scissor lock. About $30 at Napa..
Old Jul 1, 2003 | 06:43 PM
goingvet's Avatar
goingvet
Navigator
Default Re: Hood gas? struts (mash557)
They've gone up in price a bit (or they didn't give me as good a discount as they used to..), I just bought the short ones at NAPA 2 weeks ago and they were about $20 each still not a bad price. Huge difference in lifting after about half way, and as stated earlier, they will keep the hood up without the cricket leg even latching. Although I'm still in trouble shooting mode, so the long hydraulic lift that gets it going right from the start is starting to look tempting. :)
Old Jul 2, 2003 | 01:28 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Default Re: Hood gas? struts (Rykley)
Guys, I really need to update that paper now that I look at it again, but it's still worth a look. Some of the part numbers I've listed are from ZIP, but Superior is probably the best bet especially of Chris has Jeff's list of parts required. I'm listing a link to both the hood upgrade paper and also the hood alignment instructions from Mid America.
http://www.btinternet.com/~ray_quayl...d_hospital.pdf
http://www.btinternet.com/~ray_quayl...structions.pdf
To Hood gas? struts
Old Jul 3, 2003 | 04:05 AM
Rykley's Avatar
Rykley
Great Information!!!
Thanks Ray
Old Jul 3, 2003 | 04:48 AM
The13Bats's Avatar
The13Bats
Okay, I'm stupid:hat how do I open that file?
Thanx, C.
Old Jul 3, 2003 | 12:17 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
If clicking on the link doesn't open Acrobat, you'll need to download the reader. It's free here:
http://www.adobe.com/products/acrobat/readstep2.html
