Test Fans without Running to Temp?
Old Jun 30, 2003 | 01:57 PM
Southern Comfort's Avatar
Southern Comfort
Default Test Fans without Running to Temp?
Can you test the fans without running the car to the trigger points for normal operation?
Old Jun 30, 2003 | 02:50 PM
ittlfly's Avatar
ittlfly
Default Re: Test Fans without Running to Temp? (Southern Comfort)
You need to ground the A terminal to the B terminal in the ALDL connector under the dash. That will energize all the relays except the fuel pump. ( at least that is the senario on my 92)
[Modified by ittlfly, 11:51 AM 6/30/2003]
Old Jun 30, 2003 | 02:51 PM
Southern Comfort
Default Re: Test Fans without Running to Temp? (ittlfly)
Thanks! :thumbs:
Old Jun 30, 2003 | 02:52 PM
ittlfly's Avatar
ittlfly
Man..that was fast... :D
Old Jun 30, 2003 | 03:03 PM
Southern Comfort
using octane boost :auto:
According to some, shorting A to B will retrieve codes. Are you saying that with the engine running it will trigger relays?
[Modified by Southern Comfort, 12:06 PM 6/30/2003]
Old Jun 30, 2003 | 03:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Jumpering the ALDL will test the main fan (behind the radiator); to test the aux fan in front of the radiator (if so equipped) jumper the aux fan switch lead to ground and turn the ignition on.
Old Jun 30, 2003 | 03:11 PM
Southern Comfort
Default Re: Test Fans without Running to Temp? (65Z01)
where is the switch located on the 85...?
Thanks in advance
Old Jun 30, 2003 | 03:37 PM
65Z01's Avatar
65Z01
The aux fan switch is located in the block below #1 & #3 spark plugs. It's Grn wire runs into a harness along the left inner fender well.
Old Jun 30, 2003 | 04:21 PM
Tom Piper's Avatar
Tom Piper
Another way is to use a bi-directional (bi-directiona, means it can send commands, as well as, read data) scan-tool like the Vetronix Tech-1A, MasterTech, or Tech-2. However, they are expensive. This is what the dealer uses.
http://www.vetronix.com/diagnostics/mts3100/index.html
Tom Piper
Old Jun 30, 2003 | 04:35 PM
65Z01's Avatar
65Z01
That may test the main fan but not the aux fan on an L98; as the aux fan is only controlled by the aux fan switch and not at all by the ECM.
Old Jun 30, 2003 | 08:36 PM
CFI-EFI's Avatar
CFI-EFI
Make that the HEAD. Because the heads are the same, side to side, there is a similar sensor or plug between cyls, 6 and 8 on the other side of the engine. GM swapped sides for the different sensors/switches, several times. On my '84 the fan switch is on the right, between 6 & 8. I believe the left side between 1 & 3 is correct for the '85. In the opposite location, is the sending unit for the guage. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
To Test Fans without Running to Temp?
