code 42 problem please help?!!
Old Jun 30, 2003 | 02:56 PM
Damien89's Avatar
Damien89
Default code 42 problem please help?!!
I just jumpered my diag. conn.and got a code 42,the problem is that when i push at wot when i come to 4300 rpm the vette misfires in the engine bay the sound is coming like loud poping, the problem is that sometimes the problem comes on and i get the ses to light and sometimes it doesnt happen and everything is fine the proble starts straight from start up when it happens , if code 42 is the problem what should i do?
Thanks in advance guys :chevy
Old Jun 30, 2003 | 03:40 PM
ittlfly's Avatar
ittlfly
Default Re: code 42 problem please help?!! (Damien89)
Your having a problem on the coil / coil driver circuit.
Old Jun 30, 2003 | 03:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
First make sure that the connector in the Tan/Blk wire near the brake booster is firmly engaged.
If so check for a short or open in either the Tan/Blk wire or in the Wht wire from the dist. to the ECM.
If the cabling is ok the fault is either in the ignition module or the ECM.
To code 42 problem please help?!!
