94 LT1 Water Pump cost????
Old Jun 30, 2003 | 05:19 PM
meliudaj's Avatar
meliudaj
Default 94 LT1 Water Pump cost????
is $130 a good price on the water pump?
If not what price is and where do I get it?
P.S. I'm at 74k miles and swaping out the opti, I can see missing ***** on my bearing on th pump so figure it is a good idea to do both at the same time. Is that assumtion correct?
Old Jun 30, 2003 | 05:49 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Default Re: 94 LT1 Water Pump cost???? (meliudaj)
If you are paying $130 for a brand new OEM pump ~ that is a good price. I do not recommend using an aftermarket or rebuilt pump. A new pump fromSuperior Chevrolet is $151.00.
~ Purp
Old Jun 30, 2003 | 06:25 PM
John Row's Avatar
John Row
:yesnod: :yesnod: :yesnod:
Old Jun 30, 2003 | 06:38 PM
Strick's Avatar
Strick
Right about now I could go into my spiel about this whole upgrade. Look back a few weeks and you'll spot this topic covered in detail. The short form: think Meziere electric pump, DynaSpark opti or at least vent your next opti, seal replacement, plug wires and plugs. I'm doing it right know and plan on writing a Tech Tip article covering this project. I'm up to reinstalling my oil pan and the damper hub, I learned a lot about this from right here. Good luck and let me know if I can help you.
Old Jun 30, 2003 | 06:54 PM
rocketfinger's Avatar
rocketfinger
Default Re: 94 LT1 Water Pump cost???? (Strick)
:yesnod:
The electric pump is :cool: (pun somewhat intended). With my fans always on, my coolant temperature tracks load. If I'm pushing, it gets higher, I might see as high as 212 holding a steady 2200rpm with A/C at 90 degrees ambient.
Idling in traffic it actually goes down to where the thermostat modulates it, 180-185.
230 normal? :lol: :lol: :lol: :lol: pleeeeaaase!
To 94 LT1 Water Pump cost????
