Shifting problems
Old Jun 30, 2003 | 09:55 PM
Raidmagic's Avatar
Raidmagic
Default Shifting problems
O.K. So I adjust my TV cable and now the car won't shift untill 2700 rpm's from 1st to 2nd and between 2500 and 3000 from 2nd to 3rd and I can't get it to shift to overdrive. Is it possible the cable has something to do with this or is my transmission saying good bye?
Old Jun 30, 2003 | 10:40 PM
kbklt1's Avatar
kbklt1
Default Re: Shifting problems (Steve87VETTE)
this site will give you a lot of info on the TV cable and what it does.
http://www.tvmadeez.com/
Make sure you use the proper method to ajust the cable, I'm not sure on your year. Buy I know that it will change the part throttle shifts and needs to be set correct.
Maybe someone with the same year can add the how-to for it.
