Should I or shouldn't I ?
Old Jul 1, 2003 | 12:05 AM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Default Should I or shouldn't I ?
My vette's in the shop getting what I call a "performance makeover". Heads and intake ported, aligned and polished. Hi-po roller cam. Rear gears 3.54. Powder coated long-tube headers. Undersized pullys. Etc etc.
What I need advice on is while the motor is out and torn down, should I go ahead and have the rings and bearings changed also? It has 64k miles on it....and doesn't smoke or use a drop of oil between 3k oil changes. I don't intend to race it, but, well you know how Corvette drivers are.......I might "get on it" once in a while.
At this point it would only add about 3 bills extra to the overall cost. Is it worth it, or would doing so be a waste of bucks...like if it ain't broke, why fix it?
Thanks,
Karl (things ARE going to be different next year, heh heh heh)
Old Jul 1, 2003 | 12:26 AM
NightRyder's Avatar
NightRyder
Default Re: Should I or shouldn't I ? (MagikDraggin)
if you were me... or is it, if i were you...
anyways i wouldnt. i go by the if it ant broke dont fix it. unless its free. :P :lol:
Old Jul 1, 2003 | 12:27 AM
BAM92's Avatar
BAM92
300 bucks sounds cheap. IMO do it.
Old Jul 1, 2003 | 12:49 AM
Raysur's Avatar
Raysur
Default Re: Should I or shouldn't I ? (BAM92)
Cheap insurance in my book. Might as well do it since your in there. :cheers:
Old Jul 1, 2003 | 01:06 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I agree, let the bottom end alone.
All they need to do is pull the heads & intake along with the cam so don't go any further.
To Should I or shouldn't I ?
