vacuum leak after turning engine off
Old Jul 1, 2003 | 01:44 PM
kwd1's Avatar
kwd1
Default vacuum leak after turning engine off
Hi,
I noticed a hissing sound after turning the engine off. It is coming from near the
firewall on the passenger side. I haven't been able to localize it. It only happens if the heater or ac was running before turning off engine.
I also don't know if it is a vaccum leak or something outgassing.
It does it with the engine cold and warm.
any ideas?
thanks
Ken
Old Jul 1, 2003 | 01:46 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: vacuum leak after turning engine off (kwd1)
9:1 its your power brake booster....Mine used to do that. Inspect it for cracks. Or a leaky hose fitting. Its the plastic piece right behing your master cylinder.
Hope its not cracked....How are your brakes? Harder to apply than normal?
Old Jul 1, 2003 | 02:57 PM
kwd1's Avatar
kwd1
Default Re: vacuum leak after turning engine off (ski_dwn_it)
The hissing is coming from passenger side, isn't the booster on the right?
I thinks its coming from the heater/cooling system assembly near the passenger side firewall
on the outside of engine bay.
Old Jul 1, 2003 | 08:34 PM
SunCr's Avatar
SunCr
It's probably just the a/c. Once off, pressure in the high & low side equalize making the noise you describe.
Old Jul 1, 2003 | 08:47 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Mine does this too. I believe it's a/c heating or coolant related. :lurk:
Old Jul 1, 2003 | 10:19 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: vacuum leak after turning engine off (SunCr)
:withstupid: :yesnod:
Old Jul 1, 2003 | 11:28 PM
Kens86's Avatar
Kens86
It is possibly the AC heater control unit. If it is a manual unit it could be the slide or vacuum line connnections that go to it. Check to see that air flow goes to the vent, defog, and heater correctly when you move the slide to those positons Also, when you move it slowly from one positon to another do you hear it hiss? If it is only from AC to OFF you are probably ok.
Old Jul 2, 2003 | 09:37 AM
kwd1's Avatar
kwd1
Yeah it's only when the compressor is running; glad to hear it is normal.
thanks
Ken
To vacuum leak after turning engine off
