94 LT1 Aux Fan Help
Old Jul 1, 2003 | 05:59 PM
goalie31's Avatar
goalie31
Default 94 LT1 Aux Fan Help
Need some help with this ASAP. The Aux fan is not turning on, even when the AC is on. Help me fix this thing( at least diagnose it).
Bill Ankerholtz
Old Jul 1, 2003 | 11:14 PM
goalie31's Avatar
goalie31
Default Re: 94 LT1 Aux Fan Help (goalie31)
Any cooling experts out there??
Old Jul 1, 2003 | 11:23 PM
kbklt1's Avatar
kbklt1
A test light on the fan lead with the air on, or pulling a ground on the fan relay would tell you if the relay is good or not, and 12 volts applied to the fan connector it self will tell you if the motor is good or not.
Mine had a plastic bag stuck between the fan and the radiator that burned the motor out.
And mine took the fuseable link out that is behind the battery, but I think they put regular fuses on yours. Mine is a 92.
[Modified by kbklt1, 10:25 PM 7/1/2003]
To 94 LT1 Aux Fan Help
