Who here is using a Comp Cams 306 Camshaft
Old Jul 1, 2003 | 07:29 PM
robtx's Avatar
robtx
Default Who here is using a Comp Cams 306 Camshaft
Are you happy with it?
Old Jul 1, 2003 | 11:54 PM
honas's Avatar
honas
Default Re: Who here is using a Comp Cams 306 Camshaft (robtx)
I have a 305-8. If I go 10's I will love it! BH
Old Jul 2, 2003 | 11:45 AM
4DRSS's Avatar
4DRSS
Default Re: Who here is using a Comp Cams 306 Camshaft (honas)
I'm using a CC306 in my LT1. Stock shortblock and ported LT1 aluminum heads. I make 364 RWHP and 410 RWTQ in my 350 with an A4.
I am very happy with it, moves my 4,000+ lb sled to near 11 second 1/4 times. It does have a rough idle, but your extra cubes will tame that some. It is a very proven cam in LT1's, very popular.
Old Jul 2, 2003 | 06:41 PM
robtx's Avatar
robtx
Default Re: Who here is using a Comp Cams 306 Camshaft (4DRSS)
Did you get any service engine lights on after it was installed?
Old Jul 2, 2003 | 06:51 PM
96GS#007's Avatar
96GS#007
Unless you have it programmed out, you'll get a SES light and a stored P0300 random misfire code courtesy of '96 & up OBD II. '95 and earlier have OBD I and don't have this issue.
Old Jul 2, 2003 | 06:57 PM
robtx's Avatar
robtx
Default Re: Who here is using a Comp Cams 306 Camshaft (96GS#007)
It is possible to program that out? What part of the computer needs to be program to get rid of this error?
Old Jul 2, 2003 | 07:14 PM
96GS#007's Avatar
96GS#007
If you do your own programming using LT1 Edit you can disable the setting of the code and the illumination of the SES light. Likewise, Ed Wright or any of the other aftermarket tuners can do that as well. Whether you do it or a tuner does it,...it's all software :) It's not a specific part of the computer, it's part of the new flash you load.
Having said that...DanParker96 found that although it's "disabled" from a scan and SES light perspective, the code is still present and will affect the lock-up function of the torque converter if you're running an automatic (I didn't check your sig to see if you have an A4 or M6). Dan has a work-around for this. You might IM him for specifics.
To Who here is using a Comp Cams 306 Camshaft
