chip for my 1984
This is the stock 1984 automatic chip: http://jobyteknik.homeip.net/6026_bin/CDR3940.BIN
This is a GM upgrade with higher lockup speeds: http://jobyteknik.homeip.net/6026_bin/CDR8277.BIN
This is a. ECU file to use with a BIN file editor if you want to change something in the chip: http://jobyteknik.homeip.net/6026_bin/6026.ecu
And this is a free BIN file efitor: http://gmecmedit.markmansur.com/
I know this is such an old thread.
But i have a '84 Corvette and i would need the cdr3940 or cdr8277 binary file because my prom is damaged.
Can somebody tell me if these binary files are still available somewhere?
Thank you very much in advance!
Greets!
Greets!
Dynamic EFI Flash II
I attached a zip with the four L83 BIN files I have. ( Also LQ5 and LU5 BIN's that also use the 1226026 ECM )
These are the differences:
CDR3940.bin stock CDR8277.bin GM fix for TCC lockup speeds ADS8407B.bin ADS Superchip 'B'. To use with low temp thermostat hypertech 84 cfi thermalmaster.bin Address CDR3940 CDR8277 ADS8407B HYPERTECH ------- ---(d)--- ---(d)--- ---(d)--- ---(d)--- 00024 102 102 122 114 (00024 Unknown 1-byte value) 0005A 34 34 34 42 (00029-00116 Main Spark Table) 0005B 34 34 34 42 (00029-00116 Main Spark Table) 0006B 34 34 42 42 (00029-00116 Main Spark Table) 0006C 34 34 42 42 (00029-00116 Main Spark Table) 0007C 40 40 48 48 (00029-00116 Main Spark Table) 0007D 40 40 48 48 (00029-00116 Main Spark Table) 0008D 48 48 54 56 (00029-00116 Main Spark Table) 0008E 48 48 54 56 (00029-00116 Main Spark Table) 0009E 54 54 60 74 (00029-00116 Main Spark Table) 0009F 54 54 60 74 (00029-00116 Main Spark Table) 000AF 60 60 65 80 (00029-00116 Main Spark Table) 000B0 60 60 65 80 (00029-00116 Main Spark Table) 000C0 65 65 74 85 (00029-00116 Main Spark Table) 000C1 65 65 74 85 (00029-00116 Main Spark Table) 000D1 68 68 80 88 (00029-00116 Main Spark Table) 000D2 68 68 80 88 (00029-00116 Main Spark Table) 000E2 68 68 82 88 (00029-00116 Main Spark Table) 000E3 68 68 82 88 (00029-00116 Main Spark Table) 000F3 68 68 82 82 (00029-00116 Main Spark Table) 000F4 68 68 82 82 (00029-00116 Main Spark Table) 00104 68 68 82 82 (00029-00116 Main Spark Table) 00105 68 68 82 82 (00029-00116 Main Spark Table) 00115 68 68 82 82 (00029-00116 Main Spark Table) 00116 68 68 82 82 (00029-00116 Main Spark Table) 00125 51 51 57 51 (0011B-00156 Coolant Comp Spk Adv(sub cold bias)?) 0012A 51 51 57 51 (0011B-00156 Coolant Comp Spk Adv(sub cold bias)?) 00157 57 57 65 57 (0011B-00156 Coolant Comp Spk Adv(sub cold bias)?) 00158 40 40 51 40 (0011B-00156 Coolant Comp Spk Adv(sub cold bias)?) 00159 28 28 40 28 (0011B-00156 Coolant Comp Spk Adv(sub cold bias)?) 0015A 11 11 23 11 (0011B-00156 Coolant Comp Spk Adv(sub cold bias)?) 0015B 0 0 9 0 (0011B-00156 Coolant Comp Spk Adv(sub cold bias)?) 001C2 32 32 208 32 (001C2 Unknown 1-byte value) 001C4 88 88 254 88 (001C4 Unknown 1-byte value) 001DA 104 104 104 96 (001DA Unknown 1-byte value) 001E4 45 (15) 131 (44) 96 (32) 130 (43) (MPH*3 for TCC engage 3rd gear) 001E5 42 (14) 128 (43) 89 (30) 128 (43) (MPH*3 for TCC disengage 3rd gear) 001F8 80 (27) 131 (44) 128 (43) 130 (43) (MPH*3 for TCC engage 4th gear) 001F9 74 (25) 128 (43) 120 (40) 128 (43) (MPH*3 for TCC disengage 4th gear)
The stock EPROM is a 1k*8 N82S181.
Those E1 to E4 are different compared to standard EPROMS.
I used an Dataman s4 eprom programmer to read the stock chips as TI2716 chips using an adapter to handle those E-pins by connecting them to VCC and GND.
The 2716 chip is twice as big and has one extra adress pin, A10 but that is not connected when using the adapter.
By reading only the first half ( 00000-003FF ) HEX you get the chip data. If you read the whole 16k bit ( 00000-007FF ) you get the data twice. The second half will be the same again because pin A10 is not there.
It is almost impossible to get the correct N82S181 1k EPROM and I don't know how you would program it, but there is a simple solution to that.
To burn chips you should get EEPROM that are pin compatible with the 32k 2732 chip ( 4k * 8 ). It will work in the ECM without any adapter but there is one trick to make it work.
If you burn the 1k BIN data four times in a row then the status of the extra A10 and A11 pins does not matter. If I remember correctly it is the third area that will actually be used. ( 00800-00BFF ).
My 1984 has a MaxxECU controlling everything now but I am acually working on a side project to see if I can get MPG-data back on the digital dash by using a microcontroller to emulate 160 baud data.
https://www.ebay.ca/itm/10PCSAT28C16...S/253807954149
https://www.alldatasheet.com/datashe...L/AT28C16.html
Using an adapter you could also use 28C64 EEPROMS but those are 28 pin. The adapter should connect pins 2, 26 and 28 together. Pins 3-26 go straight thru to 1-24.
ACXT and APHP are BCCs for '87 '165 ECM.
BCC Lookup xls
https://xtronics.com/memory/updates.html Parallel printer port obsolete on most laptops. My laptop doesn't have one but the docking station for it does.
BCC Lookup xls
Pin 1-23 matches pin 3-25.
You should connect pins 1, 2, 26, 27 and 28 together on the DIL28 socket to get VCC from old pin 24 to all four extra pins.
You could ground pin 2 (A12) instead but the only effect would be that another 1k area of the chip would be read.
This is on my workbench now. My old 1226026 ECM with 28 pin ZIF socket for easy change of EPROMS. The extra pins are on the wrong side so I can not use a 28 pin chip in that. It would be quite easy to use a long legged chip socket as adapter for 28 pin chips. Just bending the legs and solering them together like I did when reading the stock EPROM. It would of course still be possible to use a 24 pin EPROM in that socket..
