92-96 vettes any years predisposed to be quicker than others? (LT4 excluded)
Was wondering what you guys thought about any of the LT1 cars (auto or stick) generally being quicker in one particular year than any of the other years.
Re: 92-96 vettes any years predisposed to be quicker than others? (1QWIKLT1)
The LT1 actually had minor changes over the years. I know for a fact the cam profiles vary over the years - but not significantly. I think there are also some other minor changes with engine accessories. Another significant change was the move to OBD II in 96. But I never heard anyone boasting a "93 is quicker than a 96" . If you are asking about autocross times, the earlier models with sitffer springs and the Z07 cars are quicker through the cones.
Re: 92-96 vettes any years predisposed to be quicker than others? (aggie88)
The cam changed for the 1993 year.. yielding the LT1 H.O. cam.. all it does is add another 10 ft/lbs of torque to the advertised numbers...
http://www.malcams.com/legacy/misc/CamData.htm
95 had a lot of changes including going to the 13" front brakes. I went with a 95 because I figured it had the most advancements at the time for the LT1 including the Vented Opti Spark (a must have). I don't know that it's faster than any other year though.
Re: 92-96 vettes any years predisposed to be quicker than others? (Timmy!)
I think it's a wash. The '92 has 10ftlbs less than the '93-'96. The '94-'96 have a restrictive maf setup and sequential fuel injection (a plus). The '93 has no maf but batch fire injection(a minus).
Re: 92-96 vettes any years predisposed to be quicker than others? (Strick)
I could be wrong, but usually the sticks have a better (higher #) rear end therefore quicker off the line. Why is that anyway???? Why don't the auto's come with 3.45, 3.54. 3.73 etc stock from the factory?
To answer my own question, GM figures the auto buyers are more crusing oriented?
Dunno.
Opinions/factoids?
Dunno.
Opinions/factoids?
Re: 92-96 vettes any years predisposed to be quicker than others? (froggy47)
Wouldn't it be nice if the General asked us, the Vette owners, what we would like in a Vette?
Can you imagine a 4.10 rear in a 4 speed auto? You'd be cruising at 3000 RPM all the time, and getting 15 MPG. That's why only the 6 speed manuals get the better ratios.
Re: 92-96 vettes any years predisposed to be quicker than others? (VetBoyZR1)
hmm,my 373 geared auto is abiut 1800 at 60 mph and 20 mpg.
ive read several times that up to 373 is hardly noticable in the autos,
loosing 1-2 mpg.
but 410 is sposedly a noteable difference in r's and mpg.
my car had 373's in it when i got it so i cant say what it felt like before.
but i would opt for 373 gears in it f they werent there already,from all that ive read so far...
i,e, i feel i lucked out on that :)
it hits fourth gear at 115 when w.o.t.,which is fast enough for me
makes me wonder if the darn thing wasnt way to long legged from the factory.
[Modified by mitymek, 9:46 PM 7/2/2003]
loosing 1-2 mpg.
Re: 92-96 vettes any years predisposed to be quicker than others? (mitymek)
hmm,i wonder what the gear ratio difference is between an auto in 4th with full lockup and the standard in 6th?
anyone got that info?
I know you can't reach top speed in 6th gear. 5th and 6th are overdrive.
My bias opinion is the (preOBDII) 1995 6-speed is quickest.
About gear ratios: on the ZF, the 4th gear is 1:1, 5th is 0.7:1, and 6th is 0.5:1.
The 4L60E 3rd is 1:1, 4th is 0.7:1
This is from memory, so feel free to correct me...
I had a 94 and now a 92. The biggest difference is the brand of tires on the car. The 92 hooks up WAY better with Dayton tires than the 94 ever did with the goodyears.
They're ALL good though. (until the C5.......... :skep: )
92' was the last year all 4 rims and tires were the same size.
Plus, they cheaper. :-)
Re: 92-96 vettes any years predisposed to be quicker than others? (VET 350)
There's probably more variability within each year than there is between the years. Yes, 92's probably averaged 10 ft-lbs less torque than later years, but I'll bet that the variance within each year is at least that. So, you might be able to get a 92 that's as good as the average 93.
Either way, the LT1 is a great engine. In my 92 auto, with no engine mods and a few bolt-ons (Muffler elims, 3.54 gears, K&N, etc), I just got a 13.36 at 107 mph on street tires. YMMV.
[edit - danged typos]
[Modified by MTVette, 1:13 PM 7/3/2003]
6spd's with 4.10's rock. If you have a manual it's the only way to go.. It wakes the LT-1 cars right up.
Re: 92-96 vettes any years predisposed to be quicker than others? (merrick)
[Modified by aggie88, 2:24 PM 7/3/2003]
My bias opinion is the (preOBDII) 1995 6-speed is quickest.Funny, I have the same bias. But what about Coupe vs Convertible!!!! :iagree:
Me bias man too. (But man I would love a 96 CE) (with my mods of course).
Most people think 'verts are lighter, but traditionaly, they are heavier due to the electric motors and wiring. And on many cars, vert springs are softer.
Actually, GM is looking at the bigger picture: fleet average emissions and fleet average mpg. Its an EPA thing that the automakers have to work with.
Tall gearing helps improve these averages, or rather, helps GM get in under the EPA's numbers.
Dunno.
Opinions/factoids?
Dunno.
Opinions/factoids?
