Re: [1995 LT1] Getting Caliper bolts off a problem? (Mervz)
Ahh....my 94 didn't have any caliper bolts. It just had one long pin with an "E" (don't know the tech. name) clip. Easiest caliper I have ever taken off.
There are some difference of opinion on the new bolts requirements. If you use some blue locktite on the thread, you should be OK. Short of that the bolts are $5. per. as I recall
Re: [1995 LT1] Getting Caliper bolts off a problem? (billyhay)
[Modified by billyhay, 1:38 PM 7/2/2003]
True, But to get the rotor off, The Bracket has to be un-bolted...
He's actually talking about the caliper bracket bolts, which need to come off for a rotor swap.
Anyways, you need four bolts for the front (two per side), the bolts on the rear are different. I think I just reused the rear bolts.
Re: [1995 LT1] Getting Caliper bolts off a problem? (ittlfly)
I thought you were supposed to use red formula thread lock on stud bolts?
Re: [1995 LT1] Getting Caliper bolts off a problem? (No Go)
Thanks for the suggestions guys. I'll take a look and see how bad the bolts look. Tomorrow i'll stop into a dealership and see what the TTD would be on the bolts. I have the time this weekend, so i'd love to do it then. But i don't want to rush it either. Afterall, these are my brakes for goodness sake :crazy:
Just did my 92. the calipers come off with just removing the pin. To get at the rotor you have to take off the bracket with two bolts, 21mm. My shop manual says 166 lbft on these. The rears you undo one bolt, then rotate the caliper down to replace the pads. Again to get at the rotor you have to take off the bracket. Smaller bolt size, don't remember what size, but my shop manual says 85 lbft on these.
Re: [1995 LT1] Getting Caliper bolts off a problem? (Lone Ranger)
True enough...but if you ever want to get them off again without using a 1/4 stick of c 4, I put the blue on ....10,000 miles later and all is well. :D
