jet chip
Old Jul 4, 2003 | 11:22 AM
6spd's Avatar
6spd
Default jet chip
whats up? happy 4th,does anyone know if you can run a 160 stat with a jet chip thats a 180 will it work ?
Old Jul 4, 2003 | 05:02 PM
Goody's Avatar
Goody
Default Re: jet chip (6spd)
Yes, it'll work. The difference is in the amount of timing advance between the two engine temps. Cooler engine allows more advance, hence needing 160. Else the ECM will remove the timing when it hears the pinging.
Jet chip waste of money unless it's free.
Contact Ed Wright or PCMforless or something like that.
Old Jul 4, 2003 | 11:56 PM
6spd's Avatar
6spd
Default Re: jet chip (Goody)
hi, thanks for the response, i forgot to mention the chip is for a 1991 corvette i was told any chip that i get burned will be a waste unless i go with heads,cam and so on i wanted something to advance my timing alittle and make it run a little cooler i also added tpis headers but i was told that you don't need a chip with headers. i did have a problem when i installed the headers maybe you can answer this since no else can. i get no codes and no check engine light i had it put on a scannerevery sensor is working i even have a heated oxygen sensor hear we go , when the car is in open loop it idles mint as soon as it hits closed loop and the temp gets to around 200 the idle surges i changed the iac, had it set ,had the timing, tps set can,t find a cure the car does not stall and it runs mint any thoughts thanks
Old Jul 5, 2003 | 01:25 AM
Goody's Avatar
Goody
Is everything else stock? Are you running an aftermarket throttlebody by chance? Are you certain that the O2 sensors are good?
Any chance you have an exhaust leak or vacuum leak? Hate to ask so many questions.
[Modified by Goody, 12:26 AM 7/5/2003]
Old Jul 5, 2003 | 09:28 AM
6spd's Avatar
6spd
hi, the mods are 52mm throttle body, plenum is ported i have ported edlerbrock runners tpis headers. the 02 senor is brand new msd coil it don't make sense because with a vacuum leak it would do it all the time the car acts up as soon as it goes into closed loop and the temp gets up to 200
Old Jul 5, 2003 | 10:34 PM
6spd's Avatar
6spd
Default Re: jet chip (DOCTOR J)
hi, thanks for the help i checked my runner bolts and found 2 bolts on the bottom weren't srewed in they were just sitting in the holes i pulled then out with pliers do you think this can cause a problem i have to wait till tomorrow to start my car let me know what you think thanks
To jet chip
