Rough Idle
Old Jul 5, 2003 | 11:30 AM
jrc's Avatar
jrc
Cruising
Default Rough Idle
Any suggestions? My 89 c-4 L98 has a rough idle when engine is warm. Its at the point that I have to slip it into neutral at a stand still just to keep it running. Just replaced the MAF, Throttlebody is as clean as a wistle, plugs appear to be fine. HELP!
Old Jul 5, 2003 | 12:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Rough Idle (jrc)
Clean the IAC pintel & its bore under the TB; reset base idle.
Check base timing.
Inspect vacuum lines for cracks.
Pull & inspect the plugs and inspect plug wires as well as dist cap.
Old Jul 5, 2003 | 02:08 PM
LarryK 87's Avatar
LarryK 87
Default Re: Rough Idle (65Z01)
:iagree:
especially the IAC and Vacuum parts.
Old Jul 5, 2003 | 02:09 PM
scorp508's Avatar
scorp508
Default Re: Rough Idle (LarryK 87)
Also check your TPS voltage at idle.
To Rough Idle
