L98 idle set procedure?
Old Jul 5, 2003 | 12:53 PM
scorp508's Avatar
scorp508
Default L98 idle set procedure?
I'm too lazy to search for it, whats the procedure again? :)
Old Jul 5, 2003 | 01:02 PM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: L98 idle set procedure? (scorp508)
Considering the heat, it's no wonder.
Key off
jumper A-B ALDL
key on 30 sec
disconnect IAC (key still on)
key off
pull jumper from ALDL
start up
adjust idle stop screw to ~500 rpm
key off
reconnect IAC
done
Tom
Old Jul 5, 2003 | 01:04 PM
scorp508's Avatar
scorp508
Default Re: L98 idle set procedure? (NHVett)
Thanks, Tom, I'm not even sure if my car will run at 500 RPM though with this cam. :D Its supposed to have a 900 RPM idle. I guess we'll try anyways. Thanks!
Old Jul 5, 2003 | 01:41 PM
scorp508's Avatar
scorp508
Ok that worked great, thanks. :) After adjusting the screw to get a 950 idle I redid the TPS also since it got bumped up to 0.72 at idle. Now I just have to burn a chip to match the 950 because the IAC is parked at 0 now becuase the ECM wants an 800 idle.
Old Jul 5, 2003 | 09:35 PM
Wheelman's Avatar
Wheelman
is a&b top left corner or top right?
Old Jul 6, 2003 | 05:51 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Re: L98 idle set procedure? (Wheelman)
Top Right.
Old Jul 6, 2003 | 04:17 PM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Default Re: L98 idle set procedure? (Ray Quayle)
Hi Ray, Got to Scotland June 19th rained on me the whole time. Bedbugs in Hostel. Not a good trip. Wife moved out two days ago to search for greener grass. Not a great summer so far. Now my Vette is blowing oil smoke and has a pronounced miss when tipping the throttle in at low rpms. Ain't life grand :)
Scorp, My cam/spec idle is ~750 as well. Sorry, forgot about resetting the TPS.
Tom
[Modified by NHVett, 4:19 PM 7/6/2003]
Old Jul 6, 2003 | 04:30 PM
Southern Comfort's Avatar
Southern Comfort
:grouphug: At least you still have the vette. :nopity
Wife leaving or losing the vette. Which saves the most money. Do we need a poll?
Seriously, sorry to hear that.
[Modified by Southern Comfort, 1:33 PM 7/6/2003]
Old Jul 6, 2003 | 04:42 PM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Default Re: L98 idle set procedure? (Southern Comfort)
I've got the Vette, the three Yellow Labs, the house, and she is giving me a monthly check to help w/the mortgage. And, since I don't work in the summer and only two days a week in the fall, winter and spring, I'm smiling.
Let the party begin :party:
[Modified by NHVett, 4:43 PM 7/6/2003]
Old Jul 7, 2003 | 01:03 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Tom,
Sorry I missed your IM. Feel free to e-mail anytime. Address is in sig.
Old Jul 7, 2003 | 01:37 AM
Corvette0096's Avatar
Corvette0096
What did you set your base at with that 219?
Old Jul 7, 2003 | 08:13 AM
scorp508's Avatar
scorp508
Default Re: L98 idle set procedure? (corvette0096)
950 :yesnod:
Old Jul 11, 2003 | 05:59 PM
John Steen's Avatar
John Steen
The 87 GM Service Manual says to do it this way .. Have things changed since then???? Haynes Manual goes along with NHVET ...
Key off
Jump A-B ALDL
Ignition on at least 30 sec
Disconnect IAC (key still on)
"IMPORTANT" Disconnect the distributor set-timing connector
Start Engine and allow to go to "Closed Loop"
Remove jumper A-B ALDL
Adjust to 450 rpm in neutral for manual or auto
Turn ignition off and reconnect IAC and distributor set-timing connector
Adjust TPS
John
[Modified by John Steen, 6:28 PM 7/11/2003]
Old Jul 11, 2003 | 10:59 PM
Sam Lam's Avatar
Sam Lam
Default Re: L98 idle set procedure? (John Steen)
I have to agree with John S in that the distributor connector MUST be disconnected before the idle adjustment procedure. My 89 Helms manual also states to disconnect the connector. Some guy named Lars G. wrote a procedure that is located in the tech section. I tried his method (did not break the connection) and I had a mess! I followed the Helms procedure and she purrs like a kitten. I have learned to set the TPS at about .65 volts (spec is .54 volts) to see improved idle and throttle response. Regards, Sam
To L98 idle set procedure?
