running problem
Old Jul 6, 2003 | 02:38 PM
DADDY D's Avatar
DADDY D
Default running problem
In my 86 vette i have a problem not everytime but every once in awhile. i will start my car and it will run for a second and then cut off or it will run until you touch the gas and then it will cut off any idea what is going on here and how do you fix it
Old Jul 6, 2003 | 11:40 PM
DADDY D's Avatar
DADDY D
Default Re: running problem (DADDY D)
ttt
Old Jul 7, 2003 | 12:34 AM
ciscokid's Avatar
ciscokid
At the time that it won't start is the time to get busy troubleshooting. You must catch the problem when it fresh. Remember the basics. There are three major areas for an engine to run: spark, fuel and compression. Find the area that is the issue. Once you have nailed the area down you can start looking at specifics within that area. A no start can be a needle in the haystack. Troubleshoot methodically and you will find your cause.
Some questions you might ask yourself and write down the answer to are: when does the problem seem to occur? How long? What are some of the symptoms associated with it? Did I do some work on the engine that may have caused the issue? Remember the cause and effect rule. These are just some examples. Most of all, the success of finding the cause of a problem is perserverance and perspiration.
Dig hard and you will make it happen.
Old Jul 7, 2003 | 10:23 AM
DADDY D's Avatar
DADDY D
Default Re: running problem (ciscokid)
i have done work to the engine in a year
it just comes and goes and i was wondering if there was any possible problems.
To running problem
