Error 26 Quad Driver Module
Old Jul 6, 2003 | 04:38 PM
FussBudget's Avatar
FussBudget
Default Error 26 Quad Driver Module
I bought a GM code scanner and I get an error 26 - "Quad Driver Module" or Quad Driver #1 error. Anybody know what this is? Thanks.
Old Jul 6, 2003 | 06:01 PM
Powerdrive's Avatar
Powerdrive
Default Re: Error 26 Quad Driver Module (madmanjim)
Code 26 is the AIR pump relay. Im not sure why they call it Quad driver...The bearings went bad in my pump so I disconnected it..I now flash code 26 quad driver also...Still waiting for my pump. :chevy
Old Jul 6, 2003 | 07:22 PM
FussBudget's Avatar
FussBudget
Default Re: Error 26 Quad Driver Module (Powerdrive)
Thanks, I will check out the relay.
Old Jul 6, 2003 | 07:51 PM
ittlfly's Avatar
ittlfly
That quad driver senses the A.I.R. ...EGR...and Canister purge systems. I'll bet 1 of those 3 aren't working. The ECM expects to see a certain voltage when it commands them off or on. If it doesn't then it sets the code.
Old Jul 6, 2003 | 08:35 PM
FussBudget's Avatar
FussBudget
Default Re: Error 26 Quad Driver Module (ittlfly)
Thanks, I will check the three items also.
To Error 26 Quad Driver Module
