Engine surges while stopped in drive
Old Jul 6, 2003 | 07:34 PM
eagle6's Avatar
eagle6
Default Engine surges while stopped in drive
have 1994 LT=1 Coupe and I have cleaned the throttle body but it still surges now and then when the engine heats up over 200 degrees does anybody have any idea what I can do to cure this Problem? I also replaced the IAC and ignition wires any clue?
Old Jul 6, 2003 | 07:45 PM
ittlfly's Avatar
ittlfly
Default Re: Engine surges while stopped in drive (eagle6)
Check the TPS to be sure it is operating correctly. If its worn or loose it can cause an unstable idle (ECM thinks the throttle is moving and increases injector pulse width).
