What do you use to yank it?
Old Jul 6, 2003 | 08:29 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default What do you use to yank it?
Your motor, that is. Specifically an LT1. Has anyone used the "Happy Hooker" from TPIS? It looks like it bolts right on the top of the intake with the fuel rail bolts. If this is correct, are those 8mm head bolts strong enough? Have you just used a chain and threaded 2 bolts into the front of one head and the back of the other? :confused:
Old Jul 6, 2003 | 09:02 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: What do you use to yank it? (POLOVETTE 94)
i haven't seen this set-up that you are talking about, however i have seen the ones that bolt onto the carb flange on a regular aluminum intake .they seem to do the trick. I would make sure to use all 4 of the fuel rail bolts. :cheers:
Old Jul 7, 2003 | 02:38 PM
mn_vette's Avatar
mn_vette
I pulled the exhaust manifolds and pulled it from there. Tranny and all, it was just fine. I put two chains going down to each side for stability and it was nice.
Old Jul 7, 2003 | 02:44 PM
scorp508's Avatar
scorp508
Default Re: What do you use to yank it? (mn_vette)
Longer bolts going through the eye of a chain loop in the front/left and rear/right intake manifold bolt locations.
Old Jul 7, 2003 | 02:54 PM
LD85's Avatar
LD85
Default Re: What do you use to yank it? (scorp508)
:iagree:
Or use long threads into the center of the heads were the intake bolts to the head, either way!
To What do you use to yank it?
