converting to 95 style timing cover
Old Jul 6, 2003 | 08:42 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default converting to 95 style timing cover
If converting to a 1995 timing cover and optispark, where is the best place to get it? MorePerformance has the opti, timing cover, harness, and vent tube for $499.00. Is it cheaper to just get it from the dealer? This conversion is needed to use the LT4 extreme duty timing chain and gears.
Old Jul 6, 2003 | 09:20 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Default Re: converting to 95 style timing cover (POLOVETTE 94)
Have you purchased the timing set yet? If not, I can make you a good deal on one. I went ahead and changed to the electric pump with the Cloyes double roller setup. :steering:
