Plug order 94...
Old Jul 6, 2003 | 10:43 PM
Jacobsdad's Avatar
Jacobsdad
Default Plug order 94...
Can someone give me the order of the plugs on 94...is it 1357 front to rear on drivers side and 2468 on passengers side (quiet....just checking everything to fix my miss..). Changed the plugs and can't find my miss... Changed the wires, no change (an additional busted knuckle).
Have the white manual for 94 from GM but that section is in the 93 or in the 2 volume 94 (did I tell you how lucky I am??).
Old Jul 6, 2003 | 10:46 PM
STL94LT1's Avatar
STL94LT1
Default Re: Plug order 94... (Jacobsdad)
Yes.
Old Jul 6, 2003 | 10:47 PM
Jacobsdad's Avatar
Jacobsdad
Smart @#$...Will someone give me them or confirm...there teach!!
:cry
Old Jul 7, 2003 | 09:23 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Cylinders are 1-3-5-7 on the drivers side head, 2-4-6-8 passengers front to back.
However, Opti connections for the plug wires are 1-7-3-5 on the drivers side and 2-8-6-4 on the passengers (from the bottom up). Notice that the last two are different on each side. I used to put my wires on wrong because I always though both sides were the same...first-last-2nd-3rd...but that is not the case.
A diagram can be found here...
http://csce.uark.edu/~jgbertr/rb/opti.jpg
Old Jul 7, 2003 | 09:41 PM
Jacobsdad's Avatar
Jacobsdad
Default Re: Plug order 94... (Vette92)
Thx..unfortunately they're correct. Just searching for a miss...changed plugs and had a miss (5-7 crossed). Corrected-a little better but still issues. Changed wires..still issues. Oh well, will give a little more time and take another shot..Thx for the info!! Always helpful to verify!
Old Jul 8, 2003 | 12:24 AM
BAM92's Avatar
BAM92
How old is the opti?
To Plug order 94...
