Need estimated prices,please.
Old Jul 7, 2003 | 04:59 PM
sofine89's Avatar
sofine89
Default Need estimated prices,please.
1989 coupe--automatic. Set of injectors , Any advice on what type?? Should I stay with OEM?? Also,What would I expect to pay for a NEW ECM,If i need one. Thanks guys. :cry :cry :cry :cry
Old Jul 7, 2003 | 05:14 PM
Timmy!'s Avatar
Timmy!
Default Re: Need estimated prices,please. (sofine89)
You can get the FMS (Ford Motorsport) 24lb/hr injectors for like $229 for the whole set. These would be an upgrade over OEM injectors.
Old Jul 8, 2003 | 12:10 AM
94vettin's Avatar
94vettin
I got an ECM for around 100 bucks on my 87. Do you have one sticking open, pouring gas int the manifold while the key is on? That would probably be the only reason to replace ECM. As far as injectors. If you can afford to have the car down for a couple of weeks, do some research on the internet and find a company that rebuilds them. They will dial them in so that you will have a set of 8 flowing the same. And you will come out cheaper and idle smoother. I have not done this but my friend did, I am just waiting for the need replace mine. Good luck RD
Old Jul 8, 2003 | 01:14 AM
vetteseniorcit's Avatar
vetteseniorcit
try http://www.madvet.com - set of eccel injectors (8) $299. ECM $99.99 (+ $150 core charge, refundable when you return your ECM. Or, remove your PROM and send the ECM with your order). Changing injectors is not the easiest chore in the world. An ecellent investment is a factory (GM) manual for your specific year. Could save you an awful lot of grief. Been doing business with Mid America for about 7 years and they haven't disappointed me yet.
To Need estimated prices,please.
