I installed a B&M Supercooler part # 70264. It's rated at 24,000 GVW and its dimensions are 11" x 6" x 1-1/2". You can install it w/o cutting the hard transmission cooler lines with the adapter included in the kit.
I mounted mine (94LT1) on the brackets that hold the power steering cooler. With slignt modifications, the brackets included in the kit work fine. Unfortunately, I don't have any pictures.
i mounted this same kit on another car. it is the one to go with and in terms of cooling power and price the best deal out there....believe mw I looked far and wide. Make sure to go with a stacked plate cooler, and not a tube&fin type....after i out the 160F t-stat in I never see tranny temps higher than 195 F and i have M1 synthetic ATF in there, so I am not going to put one in the vette......
