Distributor Spark Plug wiring
Old Jul 11, 2003 | 03:27 PM
B84RADR's Avatar
B84RADR
Default Re: Distributor Spark Plug wiring (Ray Quayle)
That friend of mine from AutoZone and I took out spark plug #1, cranked until we felt strong compression on it and then I manually rotated the engine over with my torque wrench till it read '0'. Then we took a look at where I had installed the distributor (keeping in mind, I took photos, but not all were clear) it looked pretty darn close to the both of us.
Tell you what. I will get back to TDC with the timing mark at '0' and then take an overhead shot at where the rotor is this afternoon if that would be helpful.
[Modified by sspackman, 4:10 PM 7/11/2003]
Old Jul 11, 2003 | 05:59 PM
scorp508's Avatar
scorp508
Default Re: Distributor Spark Plug wiring (sspackman)
:yesnod:
Next time you talk to your autozone buddy tell him to bring over a timing light with a dial on the back of it.
Old Jul 12, 2003 | 05:06 PM
B84RADR's Avatar
B84RADR
Default Re: Distributor Spark Plug wiring (scorp508)
:yesnod:
Next time I get him over here I will.
Here is ther photo that I was talking about with my #1 piston on the compression stroke, the timing mark at exactly Zero, and a shot of the rotor from above.
Old Jul 12, 2003 | 05:37 PM
B84RADR's Avatar
B84RADR
Default Re: Distributor Spark Plug wiring (grumpyvette)
Checked, re-checked and then triple checked by the guy at the autozone. Thanks for positing this graphic up here, it really helped.
Thanks,
Shayne :cheers:
Old Jul 12, 2003 | 05:40 PM
scorp508's Avatar
scorp508
Ok thats not very good looking. The screw holes in the "normal" position would look like a square from that picture. I put it in the picture below. That to me looks like it is pointing at #2.
Old Jul 12, 2003 | 05:43 PM
B84RADR's Avatar
B84RADR
You know what, I rotated it to get the other bolts out so it was a lot more square looking like your picture before. Should have thought of that!
Old Jul 12, 2003 | 05:49 PM
B84RADR's Avatar
B84RADR
This is more like what we had it at:
Look better? Or do you think I might still be one 'notch' on the distributor gear too far advanced? (if that's possible to do. I've done so much reading I can't remember any more)
[Modified by sspackman, 3:50 PM 7/12/2003]
Old Jul 12, 2003 | 05:50 PM
JCAIRE2's Avatar
JCAIRE2
What did you rotate, the body of the distributor?
Old Jul 12, 2003 | 05:52 PM
B84RADR's Avatar
B84RADR
Default Re: Distributor Spark Plug wiring (JCAIRE2)
You know what, I rotated it to get the other bolts out so it was a lot more square looking like your picture before. Should have thought of that!What did you rotate, the body of the distributor?
Yeah, the spark plug wires were making it difficult for me to get the cap of the distributor off, so I rotated it out of the way. It actually did make it quite a bit easier.
Old Jul 12, 2003 | 06:10 PM
B84RADR's Avatar
B84RADR
OK, I just had to be absolutely certain so I took spark plug 1 out and had my brother crank it over once to make sure I was at TDC. I guess I was on #6 with those previous pictures because with one revolution of the rotor, I got the compression I was looking for with cylindar 1.
So now I have manually rotated the engine of a few more degrees in its natural direction and put the timing mark right on zero.
Here are the two photos now, one close up and one for perspective.
[Modified by sspackman, 4:11 PM 7/12/2003]
[Modified by sspackman, 4:13 PM 7/12/2003]
Old Jul 12, 2003 | 06:34 PM
Caboboy's Avatar
Caboboy
You're in good shape now. Put the cap on and ID which tower the rotor points to with the greatest amount of distributor body adjustment.
Set #1 and follow the firing order around, you're good to go!! :cheers:
Old Jul 12, 2003 | 06:35 PM
scorp508's Avatar
scorp508
Default Re: Distributor Spark Plug wiring (Caboboy)
Ok thats looking better. :yesnod:
