What I learned in C4 school
Keep your weatherstriping from splitting by applying dialectric grease and wiping it clean after each wash or every 30 days. Drill a drain hole in the rubber around your gas cap as rain can get sucked into your gas tank as you drive. There is a drain tube there already but the hole is very small and plugs easily. Trust the GM engineers and do not install an air foil. The instructors have seen them carbon up on rare occasions. Installing a chip on a stock setup is shoveling $ down the drain (racing is another matter). Do not cut your aircleaner lid as you risk sucking in water. Make sure you do not overtighten your aircleaner lid as you will distort it and let unfiltered air be sucked in. Do a complete drain of your auto trans, replace the filter, and refill with synthetic tranny fluid. You car will shift better. Put a capful of Lucas power steering treatment in your power steering pump and it will help preserve the seals in your rack. If you have an automatic, reset your TV cable from time-to-time, Most are out of adjustment. (I think there is a thread in the tech section on this). Clean your throttle body from time-to-time. Many folks with crappy idle need to do this. Have soemone test your O2 sensor or better yet, just replace it. If you can, find a shop with a laser temp reader. They can point it at each injector as the motor runs and find if one is running hotter than the others. Proper flowing injectors run cooler because of the cooling effect of the fuel flow. The shop can also check the temps in front of and in behind the cat converter. If there is a difference then you have a plugged cat. Clean your engine and engine bay by spraying on Westley's Clear Majic (after you have put plastic bags over any sensitive electronics). Let it soak for a good while and then rinse off with a hose sprayer set on "mist". Do NOT blast the stuff off! If your C4 has glass headlight bulbs then replace them with plastic ones - they are much lighter and will save your headlight gears. NAPA part# HP6054. If you are doing any wiring then go to a computer supply company and invest in some metal connectors and crimp them with a roll crimper (available from SnapOn or PackardDelphi). Then heat shrink. These will be very strong and will not corrode like the cheap plastic over metal connectors. Use liquid antisieze (as used for o2 sensors) when replacing spark plugs. Use a suction gun to drain your rear end and refill with synthetic gear fluid and two (2) bottles of GM positraction additive. And last of all, they recommend Firestone Firehawks for their quiet ride/good ride/handling. Good luck and hope I don't start any :boxing
Thanks again. :cheers:
Curious about the 2 bottles of additive with synthetic in the rear end. I assumed that sythetics like Red Line already had an additive in it for limited slip and adding any of GM's additive was unecessary.
:confused:
:confused:
When I made my decision, it was between the new Goodyear F1 D3's and these Firestones. The deciding factor for me was roadnoise. My primary source of information was obtained at http://www.tirerack.com.
As it turns out, they were cheaper than the Goodyears, and had a better treadwear rating as well. I currently have 2200 miles on them, so only time will tell if the advertised treadwear rating (320) is accurate. But on all other ratings, such as wet and dry traction, cornering, and road noise, I am exceptionally pleased. To hear an endorsement from the Killebrew crew further enhances my confidence in the TireRack ratings and customer review section.
I realize I already said it, but it is worth repeating....these skins are quiet !!!
:cheers:
:eek: It just occurred to me that i left out the most important part:
Thanks for sharing all that info with us !! :flag
[Modified by Da Wiz, 11:14 PM 7/9/2003]
