I failed my emmisions exam
Old Jul 9, 2003 | 07:42 PM
87Beast's Avatar
87Beast
Default I failed my emmisions exam
I failed the idle which is supposed to be 220 for hydrocarbon and my Vette was at 967 :eek: . CO% at 1.2 while I was at 1.35 (not too bad)
I passed the cruise emmission though. I'm trying to find what is making my idle rich and why at cruising it's not so bad. And I don't have a cat but since at cruise I'm passing maybe I don't have to worry about a new one (Maybe)
Old Jul 9, 2003 | 08:07 PM
STL94LT1's Avatar
STL94LT1
Default Re: I failed my emmisions exam (87Beast)
It sounds to me like you are going to need a CAT to pass the emissions testing.
Old Jul 10, 2003 | 07:29 AM
cajun86's Avatar
cajun86
Look at this it might help you determine what to do.
http://www.mr2.com/TEXT/SmogCheck.html :cheers:
Old Jul 10, 2003 | 11:23 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Another vote for a cat. :thumbs:
Old Jul 10, 2003 | 02:17 PM
rapkobi's Avatar
rapkobi
2nd Gear
My '88 had the air pump disconnected from the centre cat, and the car failed.
Hooked up the hose, PASS.
Put the cat back on .
Old Jul 10, 2003 | 04:34 PM
OleDog's Avatar
OleDog
Default Re: I failed my emmisions exam (cajun86)
Cajun, that was excellant info.
Old Jul 10, 2003 | 05:09 PM
John Row's Avatar
John Row
I vote O2 sensors. Besides they're pretty cheap, easy to do and help mid range performance. A cat wouldn't hurt either.
Old Jul 10, 2003 | 05:12 PM
87Beast's Avatar
87Beast
Default Re: I failed my emmisions exam (John Row)
Damn these CATs to 'ell... Looks like I'll have to get one after all. Would the cat also help with a rich mixture?
Old Jul 10, 2003 | 05:21 PM
John Row's Avatar
John Row
...Would the cat also help with a rich mixture?
:nonod: O2 sensors might.
Old Jul 10, 2003 | 11:31 PM
87Beast's Avatar
87Beast
My O2 sensor is not that old 2years, but due to hte length it's been located I should get a heated sensor or relocate the bung in the collector
Old Jul 11, 2003 | 01:40 PM
John Row's Avatar
John Row
I think heated sensors are pretty much required on long tubes. Although, if you take it to the smog station after it's been heated up the sensors should be hot enough to work.
To I failed my emmisions exam
