Shifting problem?
Old Jul 10, 2003 | 11:23 AM
chrply's Avatar
chrply
Default Shifting problem?
I have a 91 Six speed some times i have trouble shifting from 1st to 2nd. if i shift at low RPM or a little high RPM its fine, but at a ceriain speed (which is my normal driving) it will not shift in second,?????? :sad:
Old Jul 10, 2003 | 12:05 PM
T1Kilr's Avatar
T1Kilr
Default Re: Shifting problem? (chrply)
Does it go in but grinds when doing so?
If so... I see new synchronizers in your future! :eek:
Old Jul 10, 2003 | 12:11 PM
don hall's Avatar
don hall
You can disable the 1-4 shift lock-out by disconnecting the relay located behind the passenger side wheel well liner (if your vette has one), or disconnecting the CAGS coupler at the transmission.
Old Jul 10, 2003 | 12:45 PM
vvv90's Avatar
vvv90
Default Re: Shifting problem? (Oldman)
Yep, simply sounds like CAGS. What it is, to the best of my knowledge, is a solenoid that engages at a certain RPM to prevent you from shifting and racing and basically doing everything the car was designed to do :crazy: :crazy: :crazy: :crazy: You can thank the insurance companies for that. Luckily it only takes about 5-10 minutes to remedy.
1.) Put the car on jack stands on the driver's side
2.) Look under the car at the bottom driver's side of the transmission.
3.) Just behind the hydraulic cylinder you'll see a little barrell shaped thing about a little bigger than a D cell battery.
4.) Pull the connector off of this thing.
Done! :cheers:
To Shifting problem?
