Dana 44 Drain Mod??
Old Jul 10, 2003 | 02:52 PM
Dougs 90's Avatar
Dougs 90
Default Dana 44 Drain Mod??
I am putting a Dana 44 in, and want to make the drain mod, I have heard several talk of this, but how is it actually done? Any reason not to do it?
Thanks,
Doug
[Modified by Dougs 90, 2:51 PM 7/10/2003]
Old Jul 10, 2003 | 05:56 PM
superlund's Avatar
superlund
Default Re: Dana 44 Drain Mod?? (Dougs 90)
I looked at pics of an open Dana 44, to determine the correct location then drilled & tapped mine for a 1/4" NPT pipe plug...no problem.
Old Jul 10, 2003 | 06:21 PM
RX7 KLR's Avatar
RX7 KLR
I had heard that some people were drilling a small hole on the inside of the case near the bottom cover bolt. Then when you remove the cover bolt it drains the diff. I don't know if that would case a weak area in the case or if it would leak, but it sounds like a good idea. Try it and we will both know if it works. :cheers:
Old Jul 11, 2003 | 01:23 AM
shamvette's Avatar
shamvette
Doug,
I am in the process of swapping my gears and drilled out for a pipe plug this past weekend. I am putting together a procedure for anyone who wants to swap their own gears and I took lots of digital pictures. I drilled the hole as close to the low point as possible, but NOT below the ring gear. I will weld in the pipe plug this Sunday, and I can post pics once I finish welding it in.....
Shamvette
Old Jul 11, 2003 | 04:59 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Dana 44 Drain Mod?? (RX7 KLR)
It seems like drilling into the lower bolt hole would make it very likely to leak from there. If I had mine out, I'd go ahead and tap a hole for a drain plug. That's of course, after switching to 3.73s.
To Dana 44 Drain Mod??
