dash cluster!!!!!!!!
Old Jul 10, 2003 | 05:11 PM
blackvette89's Avatar
blackvette89
Default dash cluster!!!!!!!!
first ride today and dash lights dimmed all still working, but very dim. directionals stay lit, and high beams stay lit?? any ideas????thanks. car is 89 :confused:
Old Jul 10, 2003 | 05:23 PM
steveb's Avatar
steveb
Default Re: dash cluster!!!!!!!! (blackvette89)
Could be caused by a loose ground wire. Some good info here for you to check out. www.batee.com/corvette/
[Modified by steveb, 4:24 PM 7/10/2003]
Old Jul 10, 2003 | 05:25 PM
blackvette89
Default Re: dash cluster!!!!!!!! (steveb)
thanks i'll check it out
Old Jul 10, 2003 | 05:30 PM
86VETTEMAN's Avatar
86VETTEMAN
Also check the Bulbs. My bulbs went out. All 4 at ounce! :mad Fixed them and as good as new. :D
Old Jul 11, 2003 | 11:25 PM
wirenut3's Avatar
wirenut3
Hi mine did the same check the plug in the side of the cluster this is were I found my problm :cool:
Old Jul 12, 2003 | 12:35 PM
blackvette89
Default Re: dash cluster!!!!!!!! (wirenut3)
what cluster? can you be more spec? thanks :cheers:
Old Jul 12, 2003 | 12:42 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
When he says Cluster, he is referring to the digital dash. There are two connectors on the right side of the Cluster, one 24 pin, the other 32 pin.
To dash cluster!!!!!!!!
