Digital Dash problem...
Old Jul 10, 2003 | 08:11 PM
CarAteMyMoney's Avatar
CarAteMyMoney
Default Digital Dash problem...
First I blew the dash fuse...
..so I put a new one in, and the dash doesnt light up anymore but you can still see the numbers in the background
Also the turn signal indicators are always lit up
Would this be a bad headlight switch? Or something else?
Old Jul 10, 2003 | 08:24 PM
SBNova's Avatar
SBNova
Default Re: Digital Dash problem... (CarAteMyMoney)
Usually if the turn signal indicators are always on its a bad ground. You may have fried the ground when you blew the fuse.
Old Jul 10, 2003 | 08:31 PM
JCAIRE2's Avatar
JCAIRE2
Check this page out: http://www.batee.com/corvette/index.shtml :cheers:
Old Jul 11, 2003 | 11:23 PM
wirenut3's Avatar
wirenut3
Hi mine did the same I have A 86 the connector that plugs into the dash cluster one of the prongs was not making contact hope this helps :cool:
To Digital Dash problem...
