Changing U-Joints, have a tool question
Old Jul 11, 2003 | 09:53 AM
jwg2's Avatar
jwg2
Default Changing U-Joints, have a tool question
Changing out my ujoints. Do I need a heavy duty vise to squeeze then out of the half shafts, or can it be done with a quality clamp?
Old Jul 11, 2003 | 09:55 AM
scorp508's Avatar
scorp508
Default Re: Changing U-Joints, have a tool question (jwg2)
It will probably have to be a hell of a clamp. :)
Old Jul 11, 2003 | 10:05 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Changing U-Joints, have a tool question (scorp508)
They make a special tool that you can use it looks like a big c-clamp. it uses dies etc and an air ratchet. When I had to put my dana 44 in, the service manager at the dealership we have, changed all the U joint on the driveshaft in under 5 minutes with it. :eek: I was used to doing the old fashion way :smash: and a big vise.
Check with Autozone you may be able to borrow/rent it.
:cheers:
Old Jul 11, 2003 | 10:21 AM
dlmeyers's Avatar
dlmeyers
Default Re: Changing U-Joints, have a tool question (ski_dwn_it)
Another option to consider, remove the shafts and head for a drive line repair facility. This is bench work, ususally pretty cheap. They will likely use a very good press and adapter.
Many options.
Good luck with the repair.
dlmeyers 90 coupe zf6 3 speed shocks
Old Jul 11, 2003 | 12:06 PM
1MoorTym's Avatar
1MoorTym
:iagree: Its a ball joint press, companies like OTC make them. Worth the money - or even borrow one from a firend like I did :D
To Changing U-Joints, have a tool question
