Engine break in procedure recap....
Old Jul 11, 2003 | 10:35 AM
mn_vette's Avatar
mn_vette
Default Engine break in procedure recap....
Well, after 3 months, 4 days, 20 hours, and 53 minutes of waiting I was promissed my engine would be done today and I could pick it up tonight after work. So that means an entire weekend of install lined up ahead of me. If I do manage to get it in without forgetting parts or breaking anything what do I do to break the engine in. I've checked the archives and this is what I've found. Please let me know if any of this if wrong.
1.) Use normal motor oil, not synthetic, for greater friction.
2.) On first startup make sure the engine gets to operating temps.
3.) Retorque the heads after first start up????
4.) Don't baby the engine, give it hard acceleration and deccelleration(sp?)
5.) Keep the engine under 4000 rpm???
6.) Change the oil at 100, 250, 500, and 1000 miles then go to synthetic.
Please let me know what you guys think. Are any of these not necessary or is there something else I'm missing. Thanks in advance. :cheers:
Old Jul 11, 2003 | 12:55 PM
Strick's Avatar
Strick
Default Re: Engine break in procedure recap.... (mn_vette)
Just thought you'd like to read this: http://mototuneusa.com/break_in_secrets.htm
It makes sence to me
[Modified by Strick, 12:56 PM 7/11/2003]
[Modified by Strick, 12:58 PM 7/11/2003]
Old Jul 11, 2003 | 01:14 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Engine break in procedure recap.... (Strick)
Let it come up to temp, then vary acceleration/deceleration for about 20 miles. Then proceed to drive it like you stole it
:cheers:
Old Jul 11, 2003 | 01:18 PM
konroh's Avatar
konroh
interesting...makes sense to me :cheers:
Old Jul 11, 2003 | 02:27 PM
86Moon's Avatar
86Moon
Default Re: Engine break in procedure recap.... (konroh)
Interesting info, what about re torqueing the heads?
Old Jul 15, 2003 | 05:46 PM
tkrussell's Avatar
tkrussell
Default Re: Engine break in procedure recap.... (86Moon)
Some thoughts:
1) It is not necessary to have maximum cylinder pressure to generate enough friction to seat the riings. Moderate acceleration from 2000 to 3000 RPM is sufficient. Microscopically, you want the high spots to burnish, but not get hot enough to weld to the opposite part.
2) Lots of engine parts need this burnishing: cam lobes, valve guides, bearings. With roller bearings, the need is less than with sliding bearings (main, rod, cam)
3) The "run 'em hard from the first" school come from the racing teams. Fair enough. Racing engines are rebuilt every 500 miles. A high performance street engine should last 50,000 miles with only valve spring refreshment.
4) I am unaware of any engineering studies demonstrating improved compression from max acceleration break in techniques.
5) I totally agree that no engine should ever be stressed until all fluids are up to temperature, fuel mix is known to be appropriate (ie, not lean), and no air pockets exist in the coolant.
6) Retorquing of the cylinder head, intake manifold, and header bolts after an initial run in of 30 minutes (with cool down) is advisable with aluminum heads. Antiseize on the threads is mandatory. Header bolts often need retorquing several times over the first month.
Hope you enjoy your new HP.
Old Jul 15, 2003 | 06:56 PM
vader86's Avatar
vader86
Id use dino for the first 2 oil changes, but I think you might be overdoing it by going at 100, 250, 500, etc. Id do one at 500, then 1000, but its not like youre going to hurt it by doing too many oil changes.
Id keep it under 3K rpm, and definitely retorque anything thats aluminum.
Old Jul 15, 2003 | 09:14 PM
torqueman2002's Avatar
torqueman2002
:iagree:
Only - - does this go for engines not built by the factory?
What about my 383 that's waiting to be wired and fired up?
To Engine break in procedure recap....
