The belt shredded on my vette as I was driving down the street, and I wanted to know if anyone knows they socket size for the belt tensioner? Also any hints would help as I have a camberbrace.
I did find the newer style of Goodyear belt seemed a little tighter (shorter) than the previous ones. Watch out for the sensor and the wire/cable routing pieces on the front of the water pump. You may want to pull the connector from the sensor ( I think there is a recent thread) and possibly pull out the routing pieces.
I believe KurtK is correct. I think it does use a 16mm. I have a Matco serpentine belt kit but it can be done with a breaker bar or ratchet just be careful and dont slip. Slip=busted knuckles :cuss
