Code 32?
Old Jul 12, 2003 | 06:14 PM
YellowVetteMan's Avatar
YellowVetteMan
Default Code 32?
Today the Service Engine Soon light came on after getting gas. The light went out after 10-15 miles. It happened twice - I tooI got a code 32 EGR Failure on the AutoXray. I could not find this code in the service manual....Any thoughts?
Old Jul 12, 2003 | 06:39 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: Code 32? (YellowVetteMan)
I had the same thing happen. The general consensus on the forum seems to be Oh well....its hot. Ignore it. Seems to be a summer thing.
Mine usually does it on the freeway after about 10 or 15 minutes....never in traffic and if I turn the car off the light stays off when I turn it back on. :crazy:
[Modified by Southern Comfort, 3:41 PM 7/12/2003]
Old Jul 12, 2003 | 07:04 PM
C10 JDR's Avatar
C10 JDR
Default Re: Code 32? (Southern Comfort)
:iagree:
Got headers?
Old Jul 12, 2003 | 07:22 PM
ittlfly's Avatar
ittlfly
Default Re: Code 32? (britvette)
:iagree:
Got headers?
:iagree: EGR problem. Seems to go hand in hand with installing after market headers.
Old Jul 12, 2003 | 09:52 PM
YellowVetteMan
No Headers.....
It did happen on the freeway and it was around 80 degrees....
Thanks for the info.
Old Jul 12, 2003 | 10:54 PM
Kens86's Avatar
Kens86
Same problem with my 86. Replaced the EGR switch. Problem solved! Mid America has the kit for $20. :yesnod:
Old Jul 13, 2003 | 05:33 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
EGR.....Just replace the EGR Valve....right?????
At least that is my thoughts...
anyway
Good Luck....
tony
:smash: :smash: :smash: :smash:
Old Jul 13, 2003 | 09:02 AM
90Z51Vette's Avatar
90Z51Vette
Default Re: Code 32? (ittlfly)
:iagree:
Got headers?
Also can happen with other exhaust changes - it started on mine when I installed my Flowmaster catback system. Basically anything that changes the backpressure on the system. My mechanic told me not to worry about it. You can get aftermarket chips that will eliminate it if you don't like looking at the warning light all the time.
To Code 32?
